Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:othermeta
The OtherMeta object is retrieved from the Metadata.other property. It provides access to miscellaneous information about the file or folder.
autodesc
string
An automatically generated description string for the item. This is the same string that is shown in the Description column in a Lister. Opus automatically generates the description for various types of files using the other metadata in ways that make the most sense.
dircount
int
For a folder, the size of which has been calculated via GetSizes or similar, this provides the number of sub-folders directly underneath the folder.
dircounttotal
int
Similar to dircount, this provides the total number of sub-folders underneath the folder (this is a recursive count - it includes sub-sub-folders, sub-sub-sub-folders, etc.)
filecount
int
For a folder, the size of which has been calculated via GetSizes or similar, this provides the number of files directly located in that folder.
filecounttotal
int
Similar to filecount, this provides the total number of files in the folder and all its sub-folders, sub-sub-folders, etc.
foldercontents
string
For a folder, the size of which has been calculated via GetSizes or similar, this returns a string giving a summary of the contents of the folder.
nsdesc
string
A description automatically generated for the item by its parent virtual file system.
rating
int
Returns the user-assigned rating for this file or folder.
target
object:Path
Returns a Path object representing the target path of shortcuts and links.
target_type
string
Returns a string indicating the type of the link (unknown, linkfile, dosfile, url, junction, softlink).
usercomment
string
Returns the user-assigned description for the file or folder.
