Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:openlisterdata
If a script add-in implements the OnOpenLister event, the method receives an OpenListerData object when invoked when a new Lister opens.
after
bool
Initially this is set to False, indicating that the event has been called before any tabs have been created. If you return True from the OnOpenLister event, it will be called again and after will be set to True to indicate all tabs have been created.
lister
object:Lister
Returns a Lister object representing the newly opened Lister.
qualifiers
string
Returns a string indicating any qualifier keys that were held down by the user when the event was triggered.
The string can contain any or all of the following: shift ctrl, alt, lwin, rwin
If no qualifiers were down, the string will be: none
