Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:menumultiselresults
The MenuMultiSelResults object is returned by the Menu.Show method when used to show a popup menu in multi-select mode.
changed
Vector
A vector of item IDs that were changed (toggled) while the menu was open.
id
int
The ID of the chosen item that dismissed the menu, or -1 if the menu was cancelled.
