Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:menuitem
The MenuItem object represents an item in a popup menu defined by a Menu. You can create a popup menu using the Dialog.CreateMenu method.
bold
bool
True if the item should appear in bold. The convention is that this indicates the menu's default action (the item that will be chosen if you press the Enter key).
checked
bool
True if the item is checked.
data
int
User data value associated with the item.
disabled
bool
True if the item appears disabled.
id
int
The numeric ID of the item. This is used in a number of Menu methods and also to identify the command chosen by the user when the menu is displayed.
label
string
The item's label.
radio
bool
For toggle items, set this to True to make it a radio toggle. You can then assign the item to a group using the Menu.AddRadioGroup method to create sets of mutually-exclusive options.
type
string
The item type. Types are "item", "toggle", "separator" and "submenu".
submenu
Menu
The sub-menu displayed by this item.
