Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:listeruichangedata
If a script add-in implements the OnListerUIChange event, the method receives a ListerUIChangeData object when various user interface elements are opened or closed in a Lister.
change
string
Returns a string indicating which UI element changed. This will equal one of the following strings: dual, tree, metapane, viewer, utility, duallayout, metapanelayout, viewerlayout, toolbars, toolbarset, toolbarsauto, minmax.
lister
object:Lister
Returns a Lister object representing the Lister that is changing.
qualifiers
string
Returns a string indicating any qualifier keys that were held down by the user when the event was triggered.
The string can contain any or all of the following: shift ctrl, alt, lwin, rwin
If no qualifiers were down, the string will be: none
