The GlobalFilters object provides information about the global file and folder filter settings (configured on the Global Filters page in Preferences). It is obtained from the DOpus.filters property.
| Property Name | Return Type | Description |
enable |
bool |
Returns True if the global wildcard filters are enabled. |
file |
string |
Returns the global filename filter wildcard pattern. If the wildcard is configured to use regular expressions, it will have a regex: prefix in front of the pattern. |
folder |
string |
Returns the global folder filter wildcard pattern. If the wildcard is configured to use regular expressions, it will have a regex: prefix in front of the pattern. |
hidehidden |
bool |
Returns True if the global option to hide hidden files is on. |
hidesystem |
bool |
Returns True if the global option to hide operating system files is on. |
permanent |
Returns a PermanentFilters object which describes the statue of the Permanent Filters. |
