Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:func
Func
The Func object is passed to a script when it is invoked via a command. In a script function, it is passed to the OnClick method as the ClickData.func property, and in a script add-in that adds an internal command, via the ScriptCommandData.func property. The Func object provides information about the default source and destination of the command, as well as details about how it was invoked.
args
object:Args
Returns an Args object that provides access to any arguments given on the command line that invoked this script. This is used when the script has added an internal command to Opus. A command line template can be provided when the command is added, and any arguments the user provides on the command line for the script command will be available via this object.
For most use the argsmap property may be an easier way to access your command's arguments.
argsmap
object:Map
Returns a Map object that provides keyword lookup for each of the arguments given on the command line. An argument will only be present in the Map if it was used on the command line, so you can easily check which arguments are present using the Map.exists() method.
button_rect
object:Rect
In functions launched by clicking a toolbar button, this provides the position on-screen of the button. You can also use the click_pt value to obtain the position of the mouse pointer. This would, for example, let you configure buttons to perform different functions depending on which part of the button was clicked.
click_button
string
In functions launched by clicking a toolbar button, this returns l, m or r to identify which mouse button was clicked (left / middle / right), or an empty string if not applicable.
click_pt
object:Point
In functions launched by clicking a toolbar button, this provides the position of the mouse pointer when the button was clicked.
command
object:Command
This property returns a pre-filled Command object that can be used to run commands against the source and destination tabs. Using this object is the equivalent of calling DOpusFactory.Command and setting the source and destination tabs manually.
desttab
object:Tab
This object represents the default destination tab for the function.
fromdrop
bool
Returns True if the command was invoked via a drag-and-drop operation.
fromkey
bool
Returns True if the command was invoked via the keyboard (i.e. via a hotkey rather than a button).
qualifiers
string
Returns a string indicating any qualifier keys that were held down by the user when the command was invoked.
The string can contain any or all of the following: shift, ctrl, alt, lwin, rwin.
If no qualifiers were down, the string will be: none
Note that any qualifiers that were actually involved in launching this command will be filtered out from this property. For example, a hotkey assigned to Ctrl+L would not report that the Ctrl key was held down, because it was integral in launching the command. Use the qualifiers_raw property to access an unfiltered set of qualifiers.
qualifiers_raw
string
Returns a string indicating any qualifier keys that were held down by the user when the command was invoked. This provides the true qualifier set, without the filtering as described above.
sourcetab
object:Tab
This object represents the default source tab for the function.
viewer
object:Viewer
If this button was run from the standalone image viewer, this object represents the viewer window.
Dlg
none
object:Dialog
Creates a new Dialog object, that lets you display dialogs and popup menus. The dialog's window property will be automatically assigned to the source tab.
