Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:fsutil
The FSUtil object provides several utility methods for dealing with the file system. It is obtained using the DOpus.FSUtil method.
CancelWatchChanges
<string:id>
none
Cancels folder or file change monitoring previously established by a call to the WatchChanges method. The id parameter is the ID you assigned to your watcher when it was created.
ComparePath
<string:path1>
<string:path2>
<string:flags>
bool
Compares the two provided path strings for equality - returns True if the two paths are equal, or False if otherwise.
The optional flags parameter lets you modify the comparison behavior. This parameter is a string containing zero or more of the following letters (case sensitive):
cMakes the path comparison case sensitive.
pReturns True if path2 is equal to or a parent of path1.
DisplayName
<string:path>
<string:flags>
string
Retrieves the display name of a path. This is the form of a path that is intended to be displayed to the user, rather than used internally by Opus. For example, for a library path it will strip off the internal ?xxxxxxx notation that Opus uses to identify library member folders.
The optional flags parameter lets you modify the behavior. This parameter is a string containing zero or more of the following letters (case sensitive):
efor editing (returns a string designed for editing rather than for display)
ffile part (returns the display filename rather than the entire path)
rresolve (resolves library paths to their underlying file system folder)
Drives
none
Vector:Drive
Returns a Vector of Drive objects, one for each drive on the system.
Exists
<string:path>
<string:flags>
bool
Returns True if the specified file, folder or device exists, or False otherwise.
The optional flags parameter can be set to w to use wildcards in the final path component.
GetADSNames
<string:path>
object:StringSet
Returns a StringSet containing the names of any alternate data streams (ADS) found for the specified file or folder.
GetErrorMsg
<int:error>
string
Returns the localized text description for a system error code.
GetFolderPair
<string:path>
<string:flags>
object:PairedFolder
Returns the pair of the specified folder, if one exists. The optional flags are compared against the configured options for the pair; they let you control in which conditions the pair is returned, and how to handle it if the paired folder doesn't exist.
dDefault dual-display folder
vDefault Navigation Lock target
nTurn on Navigation Lock automatically
yDefault Synchronize target
lAlways display primary folder at the left/top
uUse path even if it doesn't exist
iIgnore the pair
gGo up to first existing parent
GetItem
<string:path>
object:Item
Creates an Item object for the specified file path.
GetMetadata
<string:path>
object:Metadata
Returns a Metadata object representing the metadata for the specified file.
GetShellProperty
<string:path>
<string:property> or <Map:properties>
<string:type>
variant
Returns the value of one or more shell properties for the specified file.
The file path must be provided as the first parameter.
The second parameter can be the name (or PKEY) of a property to retrieve, in which case the property value will be returned.
Alternatively, the second argument can be a Map object which lets you retrieve multiple properties at once. Each property you want to retrieve should be added to the Map with its name as a key, with an empty string as its value. The values in the Map will be replaced by the property values.
The optional type argument is a string that lets you control how the properties are looked up by name (not case-sensitive):
RThe first property whose raw name matches will be used.
DThe first property whose display name matches will be used.
If neither is specified, both raw and display names can match. Note that if a shell property is returned by the system as a SAFEARRAY type, it will be converted automatically to a Vector object.
GetShellPropertyList
<string:pattern>
<string:type>
object:ShellProperty
Returns a Vector of ShellProperty objects which represents all the possible shell properties available on the system.
You can optionally provide a wildcard pattern as the first argument - if you do, only properties whose names match the supplied pattern will be returned.
The optional type argument is a string that lets you restrict the list of properties further (not case-sensitive):
RProperty raw names must match the pattern.
DProperty display names must match the pattern.
Additional flags supported by the type argument are:
VRestrict to viewable properties only. Viewable properties are those intended to be shown to the user - they're the same ones shown in Explorer's column chooser UI.
GetSignature
<string:path>
[<bool:verify> or
<string:flags>]
object:Signature
For files signed with an Authenticode certificate (usually .exe and .dll files), returns a Signature object describing the signature used to sign the file with.
By default the signature won't be verified - the method will simply extract and return information about it. The optional verify parameter lets you verify the integrity of the file as well. Set this value to True to do a simple hash check (verifies the file has not been modified, but doesn't check the signature), or use the following flags to validate the signature as well as checking the file.
nNo revocation check
c(Lowercase c.) Check final certificate in the chain for revocation
C(Uppercase C.) Check the entire chain for revocation
RCheck the entire chain excluding the root certificate
hHash-only check
lTreat certificates as expired once their timestamp has elapsed
GetTempDirPath
<int:lifetime>
object:Path
Creates a temporary folder (with a unique name) and returns the path to it in a Path object. Temporary folders created with this method have a limited lifetime after which Opus will automatically delete them (it will also clean them up when it's shutdown and restarted). The default lifetime is 20 minutes; you can change this using the optional parameter.
GetTempFile
<string:suffix>
<string:prefix>
<string:flags>
<object:window>
object:File
Creates a temporary file and returns a File object ready to be written to.
The returned object supports both reading and writing, without having to open the file a second time (although you can do that if it is easier).
You can obtain the name of the file using the File.path property.
An optional filename suffix can be specified; if not provided (or an empty string is passed), the default is ".tmp".
An optional prefix can also be specified; if not provided (or an empty string is passed), the default is "dop".
Between the suffix and prefix, Opus will insert additional characters into the name to ensure it is unique.
As an example, DOpus.FSUtil.GetTempFilePath(".txt","cat-") might generate C:\Users\Leo\AppData\Local\Temp\cat-202106230928470962.txt for a file path.
The optional flags parameter can include zero or more of these letters (not case-sensitive):
ddelete-on-close. File will be deleted automatically when closed.
ppermit deletion. Other processes can delete the file.
rread shareable. Other processes can read the file.
wwrite shareable. Other processes can write to the file.
The read, write and deletion sharing modes affect what other processes are allowed to do while the file is still open. Once the file is closed (assuming it has not been auto-deleted), other processes are always free to read, write or delete the file.
When delete-on-close is used, other things may not be able to open the file unless they specifically permit the file to be deleted at the time they open it.
The optional window parameter lets you associate the File object with a Tab or a Lister, which will be used if Opus needs to display any dialogs (e.g. a UAC elevation dialog).
GetTempFilePath
<string:suffix>
<string:prefix>
object:Path
Creates a temporary file (with a unique name) and returns the path to it in a Path object.
GetType
<string:path>
<string:flags>
string
Returns a string indicating the item type of the specified file path. The string will be either file, dir or invalid if the path doesn't exist.
The optional flags argument is used to control the behavior with archives. Normally, an archive will be reported as dir, but if you specify "a" for the flags parameter it will be reported as file.
This method is different to PathType which tells you the underlying "namespace" type rather than whether something is simply a file or a folder.
Hash
<string:path> or
<object:Blob>
<string:type> [<Dialog>]
string or object:Vector
Calculates a checksum for the specified file or Blob.
By default, the MD5 hash is calculated, but you can use the optional type parameter to change the hash/checksum algorithm. Valid values are (not case-sensitive) md5, blake3, sha1, sha256, sha512, crc32, crc32_php and crc32_php_rev.
You can also specify multiple types (e.g. "md5,sha1,sha256") at once, in which case the specified checksums will be calculated at the same time, and the result will be returned as a Vector of strings (in the same order as you requested them).
Unlike the other algorithms, CRC32 is a concept rather than a well-defined standard. We have provided the three CRC32 implementations you're most likely to encounter:
  • CRC32 is most common in the Windows world and matches what tools like 7-Zip and PKZip call "CRC32", and what PHP calls "CRC32b".
  • CRC32_PHP is less common and matches what BZIP2 uses and what PHP outputs by default.
  • CRC32_PHP_REV is the same as CRC32_PHP but with the result's byte-order reversed, as output by some tools.
Example (VBScript):
DOpus.FSUtil.Hash("C:\Windows\Notepad.exe","md5")
The optional third argument allows you to calculate the hash asynchronously and return its result to a script dialog's message loop. To use this, pass your Dialog object as the third argument. The Hash method will then return a unique ID number for the request, and your message loop will receive a "hash" message when the result is ready. The Msg.data property provides the request ID and the Msg.object property provides the hash (which will either be a string, or a Vector if more than one hash type was requested).
NewFileAttr
<attributes>
object:FileAttr
Creates a new FileAttr object, which represents file attributes.
You can initialize the new object by passing either a string representing the attributes to turn on (e.g. "hsr") or another FileAttr object. If you don't pass a value, the new object will default to all attributes turned off.
NewFileSize
<size>
or
<string:"s">
<size>
object:FileSize
Creates a new FileSize object, which makes it easier to handle 64 bit file sizes.
You can initialize this with a number of data types (int, string, decimal, currency, another FileSize object, or a Blob containing exactly 1, 2, 4 or 8 bytes). You can use a hexadecimal string by pre-pending $ or 0x.
Example (VBScript):
DOpus.FSUtil.NewFileSize(1024)
When only a size is specified, the result will be an unsigned value, which means it can represent larger size values but cannot represent negative values.
To create a signed value instead, specify "s" as the first parameter and specify the size as the second parameter. This is case-sensitive; it must be a lowercase "s".
Example (VBScript):
DOpus.FSUtil.NewFileSize("s", -1024)
NewPath
<string:path>
object:Path
Creates a new Path object initialised to the provided path string.
NewWild
<string:pattern>
<string:flags>
object:Wild
Creates a new Wild object.
If a pattern and flags are provided, the pattern will be parsed automatically; otherwise, you must call the Parse method on the returned object before using it.
See the description of the Wild.Parse method for a list of the valid flags.
OpenFile
<string:path> or <object:Blob>
<string:mode>
<object:window> or <string:elevation>
object:File
Opens or creates a file and returns a File object that lets you access its contents as binary data.
A File object is always returned, even if the file could not be opened. Check File.error on the returned object immediately after creating it to see if opening the file succeeded.
Even if a file was not be opened, some of the returned object's methods may still work. For example, if a file exists but permissions block you from opening it, you may still be able to change its attributes, or vice versa.
The first argument can be either:
  • A string or Path object which specifies the file to open.
  • An existing Blob object to create a File object that gives you read/write stream access to a chunk of memory.
When opening a Blob, the created object will always be in read-write mode and the rest of the parameters (mode and window/elevation) are not used and need not be specified.
When opening a file, the optional mode parameter specifies how to open it (case sensitive):
rRead mode. The file can be read but not written. (This is the default.)
wWrite mode. The file can be written, but not read.
rwRead-write mode. The file can be read and written from the same object.
When opening in write mode or read-write mode, you can specify additional mode flags that control how the file is created or opened (case sensitive):
cCreate a new file, only if it doesn't already exist. The call will fail if the file already exists.
aCreate a new file, always. If the file already exists, it will be overwritten, i.e. truncated to zero length. (This is the default if w or rw are used on their own.)
eOpen existing file. The call will fail if the file does not already exist.
oOpen existing file. The file will be created if it does not exist.
tTruncate existing file. If the file exists, it will be truncated to zero length. If the file doesn't exist, the call will fail.
The mode flags can also include these letters (case sensitive):
dDelete-on-close. The file will be automatically deleted when closed. (If something else also has the file open, it won't be deleted until everything closes it.)
fForce. Opus will clear the file's read-only attribute if it blocks opening the file for writing; otherwise, attempting to open a read-only file for writing will fail. For example, "wof" is like "wo" mode but also clears the read-only attribute.
mModify mode. Use this if you want to use the File object to read or modify the file's attributes, or get the file's size, without reading or writing the actual file contents.
pPermit deletion. Other processes can delete the file before it has been closed, although any deletion will not take place until it is closed. Files opened via this method always permit other readers and writers.
x(Lowercase x.) Exclude other readers. While you have the file open, nothing else can open it for reading. If something else already has it open for reading, your request to open the file will fail. Has no effect on filesystems that don't support it.
X(Uppercase X.) Exclude other writers. While you have the file open, nothing else can open it for writing. If something else already has it open for writing, your request to open the file will fail. Has no effect on filesystems that don't support it.
When opening an existing file which something else already flagged for deletion, including files already open in delete-on-close mode, the p (permit deletion) flag must be specified.
Non-Windows filesystems may have different locking and sharing rules. Opus will pass the requested flags to them, but it is ultimately up to them how they behave.
The optional third parameter takes either a window object or a string indicating elevation mode. This parameter influences the behavior of UAC elevation prompts (and potentially other user interface elements) that may be triggered when opening the file. It can be one of the following:
  • An Opus Tab or Lister object which UAC prompts will appear over if elevation is required and has not already been obtained.
  • The string "NoElevate" to prevent UAC elevation entirely when opening this file.
  • The string "ElevateNoAsk" to prevent UAC prompts while still gaining elevation if something else already got it (e.g. a previous OpenFile call).
Example (VBScript):
Set F = DOpus.FSUtil.OpenFile("C:\Test.txt","wrcf","NoElevate")
PathType
<string:path>
string
Returns a string indicating the underlying "namespace" type of the specified file path. Possible values are:
shellThe path refers to the Windows shell - e.g. a virtual folder like This PC
filesysThe path is a real filesystem path - e.g. C:\Windows
ftpThe path is an FTP path
zipThe path is a zip file
mtpThe path is an MTP path (i.e. a portable device like a phone or a tablet)
libThe path is a library
collThe path is a collection
pluginThe path is a plugin-provided namespace, most probably an archive (but not Zip)
This method is different to GetType which tells you whether something is a file or a directory.
ReadDir
<string:path>
<string:flags>
object:FolderEnum
Returns a FolderEnum object that lets you enumerate the contents of the specified folder.
The optional flags string can include zero or more flag characters (not case-sensitive):
rRecursively enumerate the folder, listing the contents of the folder, its sub-folders, their sub-folders, and so on.
lSkip links. Prevents the traversal of symbolic links and junctions when recursively enumerating folders.
sShell enumeration. Ask's the Windows Shell to enumerate non-filesystem folders. For example, the Quick Access folder on Windows 10 could be enumerated with ReadDir("/quickaccess","s"); it would not work without the "s" because Quick Access is not a real filesystem directory.
pSuppress password dialogs from encrypted archives.
If you don't need any flags, skip the second argument entirely. You may see older scripts pass True and False as the second argument, to turn recursion on and off; that is deprecated but remains supported for compatibility.
Resolve
<string:path>
<string:flags>
object:Path
Resolves the specified path string to its real filesystem path, with support for converting:
  • Folder Aliases to the real paths they point to (and vice versa).
  • Library and File Collection items to their real filesystem paths.
  • Application paths in the {apppath|appname} form.
  • Environment variables.
  • Optionally, junctions and symbolic links can be resolved to their targets.
It is safe to pass a path which does not need resolving; the path will be returned unmodified, so you can call this on things without checking if it is needed first.
Scripts which pass the current directory to external software should generally call Resolve on the path first, otherwise they risk passing aliases like /desktop to things which won't understand them.
The optional flags string can include the following letter (not case-sensitive):
cReturn canonical paths. This will expand short filenames to their true long filename representation.
jResolve junctions and symbolic links to their target folder.
aResolve path to alias (if possible)
Note that Path objects also have a similar Resolve method which modifies them in-place.
Run
<str:cmdline>
[<int:show>]
[<str:flags>]
[<str:input>]
[<str:curdir>]
[<str:encode>]
[<obj:dialog>]
or
<Map:args>
bool or
RunResults
Allows you to run external programs and optionally capture their output.
cmdline is the full command line, including any required arguments. Any paths containing spaces must be quoted.
show is the show state of (usually) the first window opened by the program. Use 0 to hide it, 1 to show it normally, 2 for minimize, 3 for maximize.
The possible values for the optional flags argument are:
aLaunch the program as administrator (elevated).
rRedirect output. The program's stdout will be redirected and returned to your script.
wWait for completion. The Run method won't return until the program exits.
Note that the r flag implies w (you can't capture output without waiting for the program to finish).
The optional input argument is any text to send to the command's stdin when it runs.
The optional curdir argument lets you specify the current directory for the launched process.
The optional encode argument lets you specify the encoding any captured output should be interpreted as. If not specified, UTF-8 is the default. Specify 0 for the current system codepage. You can also specify "raw" to receive the output as a Blob object and then convert it yourself using the StringTools methods.
If not told to wait for results, this method returns true or false.
If waiting for results, returns false on failure, or a RunResults object on success.
If running from a script dialog you can also wait asynchronously for results. Pass your Dialog handle as the seventh argument (or dialog property of the arguments map). The return value from the Run method in that case will be an ID number which identifies the task. Your message loop will receive a "run" message with this ID as the Msg.data property. The Msg.state property indicates whether the program was launched successfully or not, and the Msg.object property contains the RunResults object.
Instead of seven separate arguments, this method also supports receiving its arguments via a Map object. The parameters can be provided as values of the Map, with the following names: "command", "showcmd", "flags", "input", "cd", "codepage" and "dialog".
SameDrive
<string:path1>
<string:path2>
<string:flags>
bool
Returns True if the two specified paths both refer to the same drive or partition.
The optional flags string can contain zero or more of the following letters (case sensitive):
cConsider the CD burning staging area the same as the CD (or other writable optical media) itself.
mHandle NTFS mount points. (Slower but more accurate if either path may be below a mount point which really points to a different drive.)
rReal paths only. (Skip extra processing that is only useful for things like FTP sites and MTP devices.)
sTest if paths point to the same drive via drive letters created by the Windows subst command.
uCompare FTP users. (By default, FTP paths are considered the "same drive" if they point to the same FTP site. The u flag adds the requirement that both paths have the same user name.)
zIf path1 is inside a Zip file or other archive, only consider path2 on the "same drive" if it is the archive itself or is inside the same archive.
ZIf path1 is inside a Zip file or other archive, only consider path2 on the "same drive" if it is inside the same archive.
When neither z nor Z are specified, archives are essentially treated like normal directories and will be considered on the "same drive" as any path pointing to the same drive the archive is on, including other archive paths on that drive.
WatchChanges
<string:id>
<string:path>
<string:flags>
int
Establish monitoring of a folder or file for changes. Returns 0 for success or an error code on failure.
When a change occurs to a monitored file or folder, the script's OnFilesystemChange event is triggered.
The id argument lets you provide an ID for this watcher that's used to identify it when changes occur. dir is the full path to a filesystem folder, or a file if the i flag is set.
The optional flags are:
fmonitor for file change in folder (e.g. file created or deleted)
dmonitor for directory change in folder (e.g. directory created)
rrecursive - monitor sub-folders
amonitor for file attribute changes
smonitor for file size changes
wmonitor for last write time changes
imonitor a single file rather than a folder
Use the CancelWatchChanges method to cancel monitoring.
