Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:format
The Format object represents the current display format of a tab. It is obtained from the Tab.format property.
alpha_folders
bool
Returns True if folders are always sorted alphabetically, False if otherwise.
autosize
bool
Returns True if column width auto-sizing is enabled, False if otherwise.
checkboxes
bool
Returns True if checkbox mode is turned on, False if otherwise.
columns
collection:Column
Returns a collection of Column objects that represent all the individual columns currently added to the display.
format_explain
Vector:string
Returns a Vector of strings representing the explanation of the current folder format (the same text visible when hovering the mouse over the format lock icon in the status bar).
format_path
Path:path
Returns a Path object which represents the path that the current folder format was set for (if any).
frozen
int
Returns the number of frozen columns. Columns are always frozen from the left so this also tells you which columns are frozen (if any).
getsizes
string
Returns a string that indicates the state of the option to automatically calculate folder sizes. The string returned will be one of default, on or off.
group_by
string
If grouping is enabled, returns the name of the column that the list is grouped by.
group_combine
string
Returns a string indicating the current group combining mode. Possible values are normal, never and other.
group_individual
bool
Returns True if the group combining mode is set to Never combine. Note that this option is deprecated, you should use group_combine instead.
group_reverse
bool
Returns True if the groups are sorted in reverse order.
hide_attr
object:FileAttr
Returns a FileAttr object indicating the file attributes that are hidden (any items with these attributes set will be hidden from the display).
hide_dirs
string
Returns the wildcard pattern of folders that are hidden from the display.
hide_dirs_regex
bool
Returns True if the current hide_dirs pattern is using regular expressions.
hide_ext
bool
Returns True if filename extensions are hidden, or False if they are displayed.
hide_files
string
Returns the wildcard pattern of files that are hidden from the display.
hide_files_regex
bool
Returns True if the current hide_files pattern is using regular expressions.
hide_folder_attr
object:FileAttr
or string
Returns a FileAttr object indicating the folder attributes that are hidden (any folders with these attributes set will be hidden from the display). If the separate folder attribute filter is disabled this property will return the string "off".
ignore_prefix
string
Returns the filename prefixes that are ignored when sorting the list.
locked
bool
Returns True if the folder format is locked in the tab.
manual_sort
bool
Returns True if manual sorting is enabled.
manual_sort_name
string
If manual sorting is active, returns the name of the current sort order (if it has one).
manual_sort_order
object:SortOrder
If manual sort is active, returns a SortOrder object which lets you query and change the sort order.
mix_type
string
Returns a string indicating the current file/folder mixing type. The string returned will be one of mixed, files (files first) or dirs (folders first).
name_ext
bool
Returns True if filenames and extensions are sorted separately.
numeric_name
bool
Returns True if numeric name sorting is enabled.
reverse_sort
bool
Returns True if the over-all sort order is reversed.
show_attr
object:FileAttr
Returns a FileAttr object indicating the file attributes that are shown (only items with these attributes set will be shown in the display).
show_dirs
string
Returns the wildcard pattern of folders that are shown (only folders matching this pattern will be shown).
show_dirs_regex
bool
Returns True if the current show_dirs pattern is using regular expressions.
show_files
string
Returns the wildcard pattern of files that are shown.
show_files_regex
bool
Returns True if the current show_files pattern is using regular expressions.
show_folder_attr
object:FileAttr
or string
Returns a FileAttr object indicating the folder attributes that are shown (only folders with these attributes set will be shown in the display). If the separate folder attribute filter is disabled this property will return the string "off".
sort_ext
bool
Returns True if the name column is sorted by filename extension rather than filename.
sort_field
object:Column
Returns a Column object representing the current sort field.
thumb_size
int
Returns the custom thumbnail size, or 0 if no custom size is set.
thumb_stretch
string
If the format overrides the global thumbnail stretch mode, returns one of FitReduce, FitSmooth, FitPixelated, FillCropSmooth, or FillCropPixelated. Otherwise, returns none.
view
string
Returns the current view mode as a string. The returned string will be one of large_icons, small_icons, list, details, power, thumbnails or tile.
word_sort
bool
Returns True if word sorting is enabled.
Update
none
none
The first time a script accesses a particular Format object, a snapshot is taken of the tab's format. If the script then makes changes to that tab (e.g. it changes the sort field, etc), these changes will not be reflected by the object. To re-synchronize the object with the tab, call the Format.Update method.
