Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:filterparseerror
If a Filter object fails to parse the textual filter string you provide, you can retrieve this object from the Filter.lasterror property to find out what went wrong.
length
int
Returns the length of the token that caused the parsing error.
message
string
Returns the error description.
position
int
Returns the position of the parsing error in the input string.
token
string
Returns the token that caused the parsing error.
