Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:filesystemchangedata
A script add-in can monitor file and folder changes by implementing the OnFilesystemChange event and calling the FSUtil.WatchChanges method to establish monitoring.
id
string
Returns the ID of the watcher that detected a file or folder change. This ID is assigned when you create the watcher in the call to FSUtil.WatchChanges.
