Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:faytclosedata
If a script add-in implements the OnFAYTClose event, the method receives an FAYTCloseData object when the FAYT closes (assuming it has been used with a script FAYT command).
tab
object:Tab
Returns a Tab object representing the tab that the FAYT closed in.
