Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:displaymodechangedata
If a script add-in implements the OnDisplayModeChange event, the method receives a DisplayModeChangeData object when the display mode is changed in a tab.
mode
string
Returns a string indicating the new display mode. Will be one of largeicons, smallicons, list, details, power, thumbnails or tiles.
qualifiers
string
Returns a string indicating any qualifier keys that were held down by the user when the event was triggered.
The string can contain any or all of the following: shift ctrl, alt, lwin, rwin
If no qualifiers were down, the string will be: none
tab
object:Tab
Returns a Tab object representing the tab the display mode changed in.
