Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:dialoglistsubitem
The DialogListSubItem object represents a subitem of a DialogListItem in a Details mode list view control in a script dialog. Use the DialogListItem.subitems property to obtain a DialogListSubItems object, and then enumerate it to obtain individual DialogListSubItem objects.
<default>
text
string
Returns or sets the subitem's text. You can use the default value (e.g. subitems(0) = "blah") or the text property explicitly.
bg
string
Set or query the color used for the background (fill) of this subitem. This is in the format #RRGGBB (hexadecimal) or RRR,GGG,BBB (decimal).
fg
string
Set or query the color used for the text (foreground) of this subitem. This is in the format #RRGGBB (hexadecimal) or RRR,GGG,BBB (decimal).
styles
string
Returns or sets the text style this subitem will be displayed in. You should provide a string containing one or more of the following flags: "b" (bold), "i" (italics), "u" (underline).
