Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:dialoglistitem
The DialogListItem object represents an item in a combo box, list box or list view control in a script dialog. It's returned by the Control.GetItemAt and Control.GetItemByName methods.
bg
string
Set or query the color used for the background (fill) of this item. This is in the format #RRGGBB (hexadecimal) or RRR,GGG,BBB (decimal).
Currently only items in list view controls are supported for this property.
checked
int
For a list view control with checkboxes enabled, returns or sets the check state of the item.
Check states are 0 (unchecked), 1 (checked), 2 (indeterminate), 3 (unchecked/disabled), 4 (checked/disabled), 5 (indeterminate/disabled).
data
int
Returns or sets the optional data value associated with this item.
disabled
bool
For a list view control, returns or sets the disable state of this item. When a list view item is disabled it appears ghosted and can't be selected or right-clicked.
fg
string
Set or query the color used for the text (foreground) of this control. This is in the format #RRGGBB (hexadecimal) or RRR,GGG,BBB (decimal).
group
int
Returns or sets the list view group that this item is a member of.
icon
string
For a list view control, returns or sets the icon associated with this item. You can specify:
  • the path of a file or folder to use its icon
  • a file extension (e.g. ".txt") to use a generic filetype icon
  • "dir", "file", "ftp" or "ftps" to use generic icons
  • the path of a DLL or EXE file file followed by a comma and then the icon index within the file to extract a specific icon from the file
  • an Image object (retrieved from DOpus.LoadImage or Script.LoadImage)
  • an image markup code to use an image from the internal icon set. For example, "<%ddbi:111>".
  • a custom image markup code to use an image added via DOpus.AddMarkupImage. For example, "<%cust:test>".
index
index
Returns the 0-based index of this item within the control.
For a combo edit box, this will return -1 if the user typed in a string rather than selecting one from the list. The string they entered can be retrieved from the name property.
name
string
Returns or sets the item's name.
selected
bool
Returns or sets the item's selection state. Mostly useful with multiple-selection list box controls.
style
string
Returns or sets the text style this item will be displayed in. You should provide a string containing one or more of the following flags: "b" (bold), "i" (italics), "u" (underline).
subitems
DialogListSubItems
For a list view control in Details mode, returns a DialogListSubItems object, which contains a collection of DialogListSubItem objects (one for each column in the list, excluding the first column.) You can query or change the text of the item's sub-items, as well as assign individual colors and font styles to each sub-item.
For example, assuming the list has three columns in total, the string for the first column would be set using the name property above. The strings for the second and third columns would be set with subitems(0) and subitems(1).
