Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:dialoglistcolumn
The DialogListColumn object represents a column in a Details mode list view control in a script dialog. Use the Control.columns property to obtain a DialogListColumns object, and then enumerate it to obtain individual DialogListColumn objects.
align
string
Returns or sets the column's alignment. Valid values are "left", "right" and "center".
name
string
Returns or sets the column's name.
resize
bool
Set this property to True if you want this column to automatically resize when the list view is resized horizontally. Only one column can be set to auto-resize at a time.
sort
int
Returns 1 if the list view is currently sorted forwards by this column, -1 if it's currently sorted backwards by this column, or 0 otherwise. Settings this property will re-sort the list.
width
int
Returns or sets the column's width in pixels. Set it to -1 to automatically size the column to fit its content. You can automatically resize all columns at once using the DialogListColumns.AutoSize method.
