Sidebar
reference:scripting_reference:scripting_objects:dialog
The Dialog object allows you to display dialogs that prompt the user for confirmation, allow them to input text strings or passwords, and select checkbox options or choose from a drop-down list. You can also use this object to display a popup menu on screen.
You can create a Dialog object from the DOpus.Dlg, Lister.Dlg, Tab.Dlg, Func.Dlg and Command.Dlg methods.
See the Example Scripts section for an example of its use.
There are two different ways to use the Dialog object. You can either:
  • Use the one-shot methods (Folder, GetString, Multi, Open, Request or Save) to display a simple dialog of various types, or
  • Configure the dialog first by setting the values of the various properties, and then call the Show function to display it. This method also lets you create and use script dialogs.
The one-shot methods accept several parameters but are generally not as flexible as building up the dialog and then calling Show.
buttons
string
Specifies the buttons that are displayed at the bottom of the dialog. These buttons are used to close the dialog. The Show method returns a value indicating which button was chosen (and this value is also available in the result property).
Multiple button strings must be separated with vertical bar characters (|). If a button has more than one button then by definition the last one is the "cancel" button. For example:
dlg.buttons = "OK|Retry|Cancel"
To specify accelerators for the buttons prefix the desired key with an ampersand (&) character. For example:
dlg.buttons = "&OK|&Retry|&Cancel"
Buttons can also have drop-down menus attached to them, by separating the drop-down items with plus signs (+). For example:
dlg.buttons = "OK|Retry+Retry All|Cancel"
Within drop-down menus, you can specify that certain menu items can be accessed directly from the main button by holding Shift, Ctrl or Shift+Ctrl. This is done by adding an equals sign and then the label the button should display when the key is held down (usually an abbreviated version of the menu item label, or a repetition of the label itself if it is already short enough). The keys are automatically assigned and you can only do this for at most three items. For example:
dlg.buttons = "OK|Retry+Retry All=Retry All|Skip+Skip if same modified time=Skip Same Time|Cancel"
choices
object:Vector(string)
or array(string)
This property uses either a Vector or an array of strings to provide a list of multiple options that can be shown to the user. The list can be presented in one of three ways:
  • Drop-down list: By default, the dialog will display a drop-down list allowing the user to select one option. The index of the chosen selection is available via the selection property when the Show method returns.
  • Checkbox list: If the list property is also given the dialog will display a scrolling list of items, each with a checkbox allowing it to be turned on or off.
  • Popup menu: If the menu property is also given, a popup menu will be displayed at the current mouse coordinates. Use a single hyphen ("-") as a menu label to insert a separator.
When shown as a checkbox list the dialog is resizable; you can set the initial size using the cx and cy properties (and retrieve them afterwards if you want to save the size).
confirm
bool
In a text entry dialog (i.e. the max property has been specified) setting confirm to True will require that the user types the entered text again (in a second text field) to confirm it (e.g. for a password).
cx
int
For script dialogs marked as resizable, this property lets you override the width of the dialog defined in the resource - although note you can't resize a dialog smaller than its initial size.
cy
int
For script dialogs marked as resizable, this property lets you override the height of the dialog defined in the resource - although note you can't resize a dialog smaller than its initial size.
defvalue
string
In a text entry dialog (i.e. the max property has been specified) this property allows you to initialize the text field with a default value.
(Old scripts may use "default" instead of "defvalue"; this is deprecated because it does not work in JScript where "default" is a reserved keyword.)
defid
int
Allows you to change the default button (i.e. the action that will occur if the user hits enter) in the dialog. Normally the first button is the default - this has a defid of 1. The second button would have a defid of 2, and so on. If a dialog has more than one button then by definition the very last button is the "cancel" button, and this has a defid of 0.
detach
bool
Set to True if you want a script dialog to run in “detached” mode, where your script provides its message loop.
disable_window
object:Lister
or object:Tab
or object:Dialog\\ or int
Use this to cause the dialog to automatically disable another window when it's displayed. The user will be unable to click or type in the disabled window until the dialog is closed. Normally if you use this you would set this to the same value as the window property.
You can provide either a Lister or a Tab object, or another Dialog. If you are showing this dialog in response to the OnAboutScript event, you can also pass the value of the AboutData.window property.
icon
string or
object:Image
Displays one of several standard icons in the top-left corner of the dialog, which can be used, for example, to indicate the severity of an error condition. The valid values for this property are warning, error, info and question.
When used with a script dialog this property lets you control the icon shown in the dialog's title bar. In this instance, instead of a string you can also provide an Image object that you obtained from the DOpus.LoadImage or Script.LoadImage methods. Note that the image must have been loaded from a .ico file.
input
string
In a text entry dialog, this property returns the text string that the user entered (i.e. once the Show method has returned).
language
string
Set this property to create a script dialog in a particular language (if one or more language overlays have been provided), rather than the currently selected language.
list
object:Vector(bool)
or array(bool)\\ or int
In conjunction with the choices property, this will cause the choices to be presented as a checkbox list. You can initialize this Vector or array with the same number of items as the choices property, and set each one to True or False to control the default state of each checkbox. Or, simply set this value to 0 to activate the checkbox list without having to initialize the state of each checkbox.
When the Show method returns, this property will return a Vector of bools that provide the state of each checkbox as set by the user.
max
int
This property enables text entry in the dialog - a text field will be displayed allowing the user to enter a string. Set this property to the maximum length of the string you want the user to be able to enter (or 0 to have no limit).
When the Show method returns the text the user entered will be available in the input property.
menu
object:Vector(int)
or array(int)
or int
In conjunction with the choices property, this will cause the choices to be presented as a popup menu rather than in a dialog. The menu will be displayed at the current mouse coordinates.
You can initialize this Vector or array with the same number of items as the choices property, and set each one to a value representing various flags that control the appearance of the menu item. The available flags are as follows - their values must be added together if you need to specify more than one flag per item.
1bold (indicates the default item)
2checked (a checkmark will appear next to the item)
4radio (a radio button will appear next to the item)
8disabled (the user will not be able to select the item)
You can also simply set this value to 0 or 1 to activate the popup menu without having to provide flags for each item (if set to 1, the top item in the menu will appear bolded).
The Show method returns the index of the menu item the user chose (with 1 being the first item), or 0 if the menu was cancelled.
message
string
Specifies the message text displayed in the dialog.
msgonly
bool
Set to True before creating the dialog to create a message-only dialog. A message-only dialog will never be visible, but still runs a normal message loop. This lets you use things like WatchTab or HTTPRequest without needing a visible dialog (or resorting to opacity tricks). No dialog template is needed when using this mode. Note that only detached dialogs support this option.
opacity
int
For script dialogs this property retrieves or sets the current dialog opacity level, from 0 (totally transparent) to 255 (totally opaque).
options
collection:DialogOption
This is a collection of five options that will be displayed as checkboxes in the dialog. Unlike the choices / list scrolling checkbox list, these options are displayed as physical checkbox controls. By default the five checkboxes are uninitialized and won't be displayed, but if you assign a label to any of them they will be shown to the user.
When the Show method returns you can obtain the state of the checkboxes using the state property of each DialogOption object.
password
bool
In a text entry dialog, set this property to True to make the text entry field a password field. In a password field the characters the user enters are not displayed.
position
string
When used with a script dialog this property lets you control the dialog's position on screen. Accepted values are:
centercenter the dialog over the parent window (the default)
absolutespecify an absolute position using the x and y properties
parentposition relative to the parent window (using x and y)
monitorposition relative to the current monitor (using x and y)
Except when set to "center" the x and y properties can be used to adjust the dialog's position.
position_fix
bool
By default, Opus checks the size and position of your dialog just before it opens and fixing them if they would place any of the dialog off-screen. Positioning a dialog off-screen is usually an accident caused by saving window positions on one system and restoring them on another with different monitor resolutions or arrangements. In the rare cases where you want your dialog to open off-screen, where the user cannot see some of all of it, set this property to False.
result
int
This property returns the index of the button chosen by the user to close the dialog. The left-most button is index 1, the next button is index 2, and so on. If a dialog has more than one button then by definition the last (right-most) button is the "cancel" button and so this will return index 0.
If any buttons have associated drop-down menus then the contents of the menus also contribute to the index value. For example, if button index 2 has an additional item in a drop-down menu, then that item would be index 3, and the next button would be index 4.
select
bool
In a text entry dialog, set this property to True to automatically select the contents of the input field (as specified by the defvalue property) when the dialog opens.
selection
int
In a drop-down list dialog (one with the choices property set without either list or menu), this property returns the index of the item chosen from the drop-down list after the Show method returns.
singleton
string
If you only want one instance of your dialog to be open at once, set this property to a unique name before creating the dialog. When the dialog is created, Opus will check if another dialog with same singleton name is already open. If it is, the existing dialog will be brought to the front and your script will receive a False return from the Create or Show methods. You should check for this an exit your script in that case.
sort
bool
Set this property to True if the list of choices given by the choices property should be sorted alphabetically.
state
string
Returns a string indicating the current state of the dialog. Possible values are "visible" (normal state, open and visible), "hidden" (dialog has been hidden), "min" (dialog is minimized), "max" (dialog is visible and maximized).
template
string
Lets you create a script dialog. The template property can be set to the name of the script dialog to display (as defined in your script resources), or a string that contains raw XML defining the dialog.
title
string
Specifies the title text of the dialog.
top
bool
Set this property to True to make the dialog "top level", or False to allow it to go behind other non-top level windows.
want_close
bool
Set this property to True if you want the script dialog to generate close events in your message loop when the user clicks the window close button. You'll need to close the dialog yourself using the EndDlg method.
want_move
bool
Set this property to True if you want the script dialog to generate move events in your message loop when the dialog is moved.
want_resize
bool
Set this property to True if you want the script dialog to generate resize events in your message loop when the dialog is resized.
window
object:Lister
or object:Tab
or object:Dialog
or int
Use this to specify the parent window of the dialog. The dialog will appear centered over the top of the specified window. You can provide either a Lister or a Tab object, or another Dialog. If you are showing this dialog in response to the OnAboutScript event, you can also pass the value of the AboutData.window property.
You only need to set this property if you obtain the Dialog option from the DOpus.Dlg method. If the Dialog object comes from one of the other objects (e.g. Tab.Dlg) then its parent window will already be set to the window which launched the action your script is responding to.
x
int
Specifies the x-position of a script dialog. Use the position property to control how the position is interpreted. After the dialog has been displayed you can change this property to move the dialog around on-screen.
y
int
Specifies the y-position of a script dialog. Use the position property to control how the position is interpreted. After the dialog has been displayed you can change this property to move the dialog around on-screen.
AddCustomMsg
<string:name>
[<bool:force>]
bool
Lets a script dialog register one or more custom messages that can then be sent to it from other scripts.
Messages are registered by name. If a message is already registered the method will fail unless you set the optional force parameter to true.
Use DOpus.SendCustomMsg to send messages to dialogs. The dialog will receive a "custom" Msg in their message loop.
AddHotkey
<string:name>
<string:key>
bool
Creates a hotkey (or keyboard accelerator) for the specified key combination. When the user presses this key combination in your dialog, a hotkey event will be triggered.
The name parameter is a name you assign that lets you identify the hotkey. The key parameter specified the actual key combination; this can optionally combine the qualifiers ctrl, shift and alt with a character or name of a special key. For example, ctrl+t or alt+shift+F7.
This method returns true if successful, or false on failure (e.g. if the hotkey already exists).
AutoSize
none
none
If a dialog has auto-sizing controls that depend on the sizes of other controls, and you make changes to their sizes at runtime, you can call this method to force the dialog to recalculate all relative control sizes once you've made the required changes.
CancelWatchClipboard
none
none
Cancels monitoring of the system clipboard for changes previously established by a call to the WatchClipboard method.
CancelWatchDir
<string:id>
none
Cancels folder or file change monitoring previously established by a call to the WatchDir method. The id parameter is the ID you assigned to your watcher when it was created.
Create
none
none
When creating a script dialog, calling this method creates the underlying dialog but does not display it. This lets you create the dialog and then initialize its controls before it is shown to the user.
Using Create implies a detached dialog; the detach property will be set True automatically. However, you can call RunDlg afterwards if you don't need a custom message loop and just want to set up some controls before displaying the dialog.
Once the dialog has been created and its controls initialized, you should call Show or RunDlg to make it visible to the user. It will also go visible at the first GetMsg call if it hasn't already been shown.
ClientToScreen
<int:X>
<int:Y>
Rect
Takes an x,y pixel position relative to the dialog's client area and returns the same coordinates relative to the whole screen.
The client area is the area inside the dialog's window frame, excluding the frame itself, with coordinates relative to the top left. The screen coordinates are relative to the top-left corner of the primary monitor. Coordinates can be negative if the mouse is to the left or top of the respective areas.
While a rectangle is returned, only the left and top coordinates are meaningful. The width and height will always be zero.
CreateFont
<string:name>
[<int:size>]
[<string:styles>]
int
Creates a font object that can be given to dialog controls to make them use a non-standard font. The name parameter specifies the name of the font (e.g. "Arial") - you can also use "*" which means the default dialog font. The size parameter specifies the desired point size (use 0 to get the default dialog font size). The styles string can consist of one or more characters indicating the desired font style - "b" for bold, "i" for italic, "u" for underline.
The return value can be used with the Control.SetFont method.
Fonts you create are automatically destroyed when the dialog closes but if you want to delete them manually to free up resources, use the DestroyFont method.
Control
<string:name>
[<string:dialog>]
[<string:tab>]
object:Control
Returns a Control object corresponding to one of the controls on a script dialog. The control is identified by its name, as defined in the script dialog resource.
The optional second and third parameters are only used when the control is in a tab control (that is, when it's in a dialog that's a child of another dialog). The dialog parameter specifies the name of its parent dialog. The tab parameter specifies the name of the tab control hosting the child dialog. You would only need to specify the name of the tab if you have multiple tab controls and the same dialog is hosted inside more than one of them (this would be quite a rare occurrence).
Note that none of the controls will exist until Create has been called.
DelHotkey
<string:name>
bool
Deletes a hotkey you previously created with the AddHotkey method.
This method returns true if successful, or false on failure (e.g. if the hotkey does not exist).
Drag
object:Items
<string:actions>
string
Allows the user to drag and drop one or more files from your dialog (and drop them in another window or application).
You would usually call this in response to a drag event you receive from a static or list view control.
The first parameter is an Items object representing the files to be dragged. (You can also pass a Vector of Item or Path objects, or full path strings, instead of an Items object. Or a StringSet or UnorderedSet of full path strings.)
The optional second parameter lets you control which actions are available. This should be a string containing one or more of copy, move, link. The default action can be indicated by prefixing it with a * (e.g. copy,*move,link). If you don't specify this parameter the default is to only allow copy.
The string this method returns indicates the result of the drag. For a left button drag, this will be "copy", "move", "link" or "drop". For a right-button drag it will always be "drop". If the drag is cancelled it will return "cancel".
DestroyFont
<int:id>
none
Destroys the specified font using the ID that was returned by the CreateFont method.
EndDlg
<int:result>
none
Ends a script dialog running in detached mode. Normally dialogs end automatically when the user clicks the close button or another button that has its Close Dialog property set to True. This method lets you end a dialog under script control. The optional parameter specifies the result code that the Dialog.result property will return.
Folder
<string:title>
<string:default>
<bool:expand>
<object:window>
object:Path
Displays a "Browse for Folder" dialog letting the user select a folder. The optional parameters are:
  • title - specify title of the dialog
  • default - specify the default path selected in the dialog
  • expand - specify True to automatically expand the initial path
  • window - specify parent window for the dialog (a Lister or a Tab). If not specified, the Dialog object's window property will be used.
A Path object is returned to indicate the folder chosen by the user. This object will have an additional result property that will be False if the user cancelled the dialog - the other normal Path properties will only be valid if result is True.
FlushMsg
none
int
Flushes the dialog's message queue. Any unretrieved messages will be discarded. The return value tells you how many messages were in the queue.
GetFocus
none
string
Returns the name of the control in the dialog that currently has the input focus (if any).
GetMsg
none
object:Msg
Returns a Msg object representing the most recent input event in a script dialog (only used in detached mode).
The return value will evaluate to False when the dialog is closed, which is when you should exit your message loop.
If the dialog is not already visible (because Show has not been called) then it will become visible when you first call GetMsg.
GetString
<string:message>
<string:default>
<string:max>
<string:buttons>
<string:title>
<object:window>
<byref string:result>
string
Displays a text entry dialog allowing the user to enter a string. The optional parameters are:
  • message - specify message string in the dialog
  • default - specify default string value
  • max - specify maximum string length
  • buttons - specify button labels (in the same format as the buttons property described above)
  • title - specify dialog window title
  • result - for scripting languages that support ByRef parameters, this can specify a variable to receive the string the user enters.
The return value is the entered string, or an empty value if the dialog was cancelled. The index of the button selected by the user will be available via the result property once this method returns. The left-most button is index 1, the next button is index 2, and so on. If a dialog has more than one button then by definition the last (right-most) button is the "cancel" button and so this will return index 0.
KillTimer
<string:name>
none
Stops the specified timer. The timer must previously have been created by a call to the SetTimer method.
The timer is stopped asynchronously and, for a short period of time, it is still possible for a timer to fire again even after calling KillTimer. If that is a problem, use the SetTimer method's oneshot parameter so the timer is automatically and synchronously stopped the first time it fires.
LoadPosition
<string:id>
<string:type>
none
Restores the previously saved position of a script dialog. The position must have previously been saved by a call to the SavePosition method.
The id string is a string that Opus can use to identify your dialog or the script it comes from. The template name of the dialog will be automatically appended to this. For example, you might specify id as "kundal" - Opus would then internally save the position of a dialog called "dialog1" as "kundal!dialog1". Make sure you pick a string that other script authors are unlikely to use as Opus has no other way of telling the saved positions apart.
The optional type parameter lets you control which position elements are restored - specify "pos" to only restore the position, "size" to only restore the size, or "pos,size" to restore both (this is also the default, so you can also omit the argument all together).
Multi
<string:title>
<string:default>
<object:window>
<string:type>
object:Items
Displays a "Browse to Open File" dialog that lets the user select one or more files. The optional parameters are:
  • default - specify the default file selected in the dialog (if a folder is specified this specifies the default location but no file will be selected)
  • window - specify parent window for the dialog (a Lister or a Tab). If not specified, the Dialog object's window property will be used. (Omit the window argument entirely if you don't want to use it; the type argument, if used, works whether third or fourth.)
  • type - A list of filetypes to populate the "Save as Type" dropdown in the save dialog. (See below.)
The optional type parameter consists of one or more pairs of strings, separated by exclamation marks (!). The first string of each pair is the plain text string shown in the drop-down, and the second string of each pair is the actual file extension. You can also specify multiple extensions for the one type by separating them with semicolon. If you want the default "All files" item to be added to the list, add a # character at the start of the string. For example, #Text Files!*.txt!Doc Files!*.doc.
An Items object is returned to indicate the files selected by the user. The returned object will have a result property that you should check first - the collection of items is only valid if result returns True. If it returns False it means the user cancelled the dialog.
NewHTTPReq
none
object:HTTPRequest
Creates a new HTTPRequest object attached to this dialog. This object provides a simple way to send an HTTP request to a server asynchronously, and retrieve the response.
Events from HTTP requests will come through your dialog's message loop, so you must use a detached dialog in order to use this functionality.
NotifyIcon
<string:method>
arguments…
none
Allows a script to add an icon to the system taskbar notification area.
The method argument specifies one of four actions, each of which has its own set of arguments.
methodArgumentsDescription
add<icon>,
<tooltip>
Add icon to the toolbar.
update<icon>,
<tooltip>
Updates icon or tooltip.
removenoneRemoves the icon.
notify<title>,
<message>,
<flags>
Displays a system notification message (or bubble tooltip in Windows 7).
For the add and update methods, the icon argument can be a string or Image object - see the documentation for the icon property above for more details. If the dialog has been assigned an icon via this property then that icon will be used automatically if none is provided.
The tooltip argument provides a tooltip string that the system will display when the user moves the mouse over the icon. If the dialog's title property has been set then the title will be used if no explicit tooltip is given.
The notify method lets you show a system notification associated with your dialog. This method is similar to the DOpus.Notify method - see the description of that method for more information on the arguments.
Once your script has added an icon, the user can interact with it using the mouse. Mouse activity will generate click, dblclk and rclick events in your dialog's message loop. The Msg.control property will be set to notifyicon.
The icon is automatically removed when your dialog closes. It's also restored automatically if Explorer restarts after the icon has been added.
Please note that only one icon per dialog is supported.
Open
<string:title>
<string:default>
<object:window>
<string:type>
object:Item
Displays a "Browse to Open File" dialog that lets the user select a single file. The optional parameters are:
Set the type parameter to the string "folder" to use this dialog to select a folder (instead of via the Folder method).
A single Item object is returned to indicate the file selected by the user. This object will have an additional result property that will be False if the user cancelled the dialog - the other normal Item properties will only be valid if result is True.
Request
<string:message>
<string:buttons>
<string:title>
<object:window>
int
Displays a dialog with one or more buttons. The optional parameters are:
The return value is the index of the button selected by the user, and this is also available in the result property once the method returns. The left-most button is index 1, the next button is index 2, and so on. If a dialog has more than one button then by definition the last (right-most) button is the "cancel" button and so this will return index 0.
RunDlg
none
int
Turns a previously detached dialog into a non-detached one, by taking over and running the default message loop. The RunDlg method won't return until the dialog has closed. You might use this if you created a dialog using Create, in order to initialize its controls, but don't actually want to run an interactive message loop.
The return value is the same as the object's result property, and represents the index of the close button selected by the user.
If the dialog is not already visible (because neither Show nor GetMsg were called) then it will become visible when you call RunDlg. (Compatibility note: Prior to Opus 12.22, scripts needed to call Show explicitly.)
Save
<string:title>
<string:default>
<object:window>
<string:type>
object:Path
Displays a "Browse to Save File" dialog that lets the user select a single file or enter a new filename to save. The optional parameters are:
  • title - The dialog's title.
  • default - The default file selected in the dialog. (If a folder is given, it sets the dialog's starting location, but no file will be selected.)
  • window - The dialog's parent window (a Lister or a Tab). If not specified, the Dialog object's window property will be used. (Omit the window argument entirely if you don't want to use it; the type argument, if used, works whether third or fourth.)
A Path object is returned to indicate the file chosen by the user. This object will have an additional result property that will be False if the user cancelled the dialog, and the other normal Path properties will only be valid if result is True.
SavePosition
<string:id>
none
Saves the position (and size) of the dialog to your Opus configuration. The position can then be restored later on by a call to LoadPosition.
Normally you would call LoadPosition before displaying your dialog, and SavePosition after the dialog has been closed.
ScreenToClient
<int:X>
<int:Y>
Rect
Takes an x,y pixel position relative to the whole screen and returns the same coordinates relative to the dialog's client area.
SetFocus
<string:name>
bool
Sets the input focus to the named control within this dialog. Equivalent to Control("name").focus = true;.
SetTimer
<int:period>
<string:name>
<bool:oneshot>
string
Creates a timer that will generate a periodic timer event for your script. The period must be specified in milliseconds (e.g. 1000 would equal one second).
You can optionally specify a name for the timer - if you don't provide a name, one will be generated automatically (and the name of the new timer will be returned).
The optional oneshot parameter can be set True to automatically and synchronously kill the timer the first time it fires. (The script should then call SetTimer again if it wants the timer to fire again.) The oneshot parameter should be set True if it is important that no extra timer events happen. If oneshot is False or omitted, it is possible for a timer to fire again even if you call KillTimer in response to it the first time, because the dialog timer events and KillTimer calls are asynchronous.
Show
none
int
Displays the dialog that has been pre-configured using the various properties of this object. See the properties section above for a full description of these.
If the detach property is False, the call will not return until the dialog has been closed. The return value is the index of the button selected by the user, and this is also available in the result property once the method returns. The left-most button is index 1, the next button is index 2, and so on. If a dialog has more than one button then by definition the last (right-most) button is the "cancel" button and so this will return index 0.
If the detach property is True, the call will return immediately and the return value is meaningless. You should then either run a message loop for the “detached” dialog, or call RunDlg to run the standard loop.
Note that calling Create implicitly sets the detach property to True. If you need to create the dialog to modify some of its controls before it is displayed, but do not want to run your own message loop once it is displayed, you should call RunDlg rather than Show.
SetTaskbarGroup
<string:group>
bool
Used to change how custom dialogs are grouped with other Opus windows on the taskbar. Specify a group name to move the window into an alternative group, or omit the group argument to reset back to the default group. If one or more windows are moved into the same group, they will be grouped together, separate from other the default group.
This only works on Windows 7 and above, and only when taskbar grouping is enabled. Group names are limited to 103 characters and will be truncated if longer. Spaces and dots in group names are automatically converted to underscores.
Only works with custom script dialogs (i.e. when you are using the template property). Must be called after the dialog has been created (i.e. after Show has been called – see the RunDlg method if you want to avoid writing your own message loop just for this).
Returns true on success.
Vars
<string:id>
object:Vars
Returns a Vars object that represents the variables that are scoped to this particular dialog. This allows scripts to use variables that persist from one use of the dialog to another.
The id string is a string that Opus can use to identify your dialog or the script it comes from. The template name of the dialog will be automatically appended to this. For example, you might specify id as "kundal" - Opus would then internally save these variables for a dialog called "dialog1" as "kundal!dialog1". Make sure you pick a string that other script authors are unlikely to use as Opus has no other way of telling the saved variables apart.
WatchClipboard
none
bool
Establish monitoring of the system clipboard. Whenever the system clipboard contents change, the dialog's message loop receives a clipboard event.
Use the CancelWatchClipboard method to cancel monitoring.
WatchDir
<string:id>
<string:path>
<string:flags>
int
Establish monitoring of a folder or file for changes. Returns 0 for success or an error code on failure.
The id argument lets you provide an ID for this watcher that's used to identify it when changes occur. dir is the full path to a filesystem folder, or a file if the i flag is set.
The optional flags are:
fmonitor for file change in folder (e.g. file created or deleted)
dmonitor for directory change in folder (e.g. directory created)
rrecursive - monitor sub-folders
amonitor for file attribute changes
smonitor for file size changes
wmonitor for last write time changes
imonitor a single file rather than a folder
When a change occurs to a monitored file or folder, the dialog's message loop receives a dirchange event. The Msg.control property identifies the watcher's ID.
Use the CancelWatchDir method to cancel monitoring.
WatchTab
<object:Tab>
<string:events>
<string:id>
bool
Allows a script dialog to monitor events in a folder tab. You will receive notifications of the requested events through your message loop.
The tab parameter specifies the Tab you want to watch. The events string is a comma-separated list of events you want to watch for. The id string is an optional parameter; it lets you assign your own ID to the tab to make it easier to tell where events are coming from (if you're monitoring multiple tabs, for instance).
These are the events you can watch for. Note that some are equivalent to the script events (e.g. OnActivateTab):
selectitems in the tab are selected or deselected
navigatethe folder is changed in the tab
additems are added to the folder
deleteitems are deleted from the folder
filechangeitems in the folder are changed (size, date, name, etc)
activatetab activated or deactivated
srcdstsource/destination state changed
viewview mode changed
flatflat view state changed
filterquick filter changed
Once notification has been established you will be notified of all requested events when they occur. Note that no specific information is sent with notifications - e.g. for the "filechange" event, you aren't told which items have changed, only that something has.
You will receive notification events in your message loop. The various properties of the Msg object let you determine what happened.
The Msg.event property will be set to tab for notifications from a watched folder tab.
The Msg.control property tells you which tab the change occurred in; if you specified an ID when you called the WatchTab function, this will be in the Msg.control property - otherwise, it will be the numeric handle of the tab. Note that it's *not* the actual Tab object. You can access the Tab object via the Msg.tab property but this can be inefficient, as it requires a new Tab object to be created every time. If you're only monitoring one tab it's better to store the Tab object in your own variable - and if you're monitoring multiple tabs you could, e.g. use a unique ID for each one and keep the objects in a Map.
The Msg.value property tells you which notification event occurred. Possible values are select, navigate, filechange, activate, srcdst, view, flat, filter and close (sent if the tab is closed while you are monitoring it).
For the filechange event, the Msg.data property contains a bit mask indicating which file events occurred. 1 = add, 2 = delete, 4 = change. The values will be added together (so e.g. 6 indicates at least one item was changed and at least one was deleted). It's up to your script to determine exactly what changed.
You can change the events you're monitoring for by calling the WatchTab method again with the same tab and new event list.
To stop monitoring an existing tab, call WatchTab with the second parameter set to stop. Monitoring is automatically cancelled if your dialog closes (and also if the tab closes).
WindowCmd
<string:command>
none
Sends a command to the dialog window to change how it's displayed. Possible commands are:
minminimize the window
maxmaximize the window
restorerestore the window (from minimize/maximize)
showshow the window if it's currently hidden
shownashow the window but don't activate it
hidehide the window
frontactivate the window and bring it to the front
