Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:deletescriptdata
If a script add-in implements the OnDeleteScript event, the method receives a DeleteScriptData object when the script is deleted by the user.
file
string
Returns the full pathname of the script file being deleted.
