Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:control
The Control object represents a control on a script dialog; it lets you read and modify a control's value (and contents). Use the Dialog.Control method to obtain a Control object.
bg
string
Set or query the color used for the background (fill) of this control. This is in the format #RRGGBB (hexadecimal) or RRR,GGG,BBB (decimal). Currently only static text, markup text, button and list view controls are supported for this property.
charcase
string
For an edit control, gets or sets the control's case setting. Values are upper, lower and normal.
columns
DialogListColumns
For a list view control, returns a DialogListColumns object that lets you query or modify the columns in Details mode.
controlname
string
Returns the name of the control. This is the same name used to identify the control in dialog resources and Msg objects that notify you about clicks or other events involving a control.
count
int
Returns the number of items contained in the control (e.g. in a combo box, list box or list view, returns the number of items in the list).
cuetext
string
Get or set the cue text of a single-line edit control. This is the text shown to help the user when the edit control is empty.
cx
int
Set or query the width of the control, in pixels.
cy
int
Set or query the height of the control, in pixels.
enabled
bool
Set or query the enabled state of the control. Returns True if the control is enabled, False if it's disabled. You can set this property to change the state.
fg
string
Set or query the color used for the text (foreground) of this control. This is in the format #RRGGBB (hexadecimal) or RRR,GGG,BBB (decimal). Currently only static text, markup text, button and list view controls are supported for this property.
focus
bool
Set or query the input focus state of the control. Returns True if the control currently has input focus, False if it doesn't. Set to True to give the control input focus.
hwnd
int
Returns the control's underlying window handle. Not directly usable in Opus but you may want this if interfacing with automation tools.
string or
object:Image
For a button or static control set to image mode, this assigns an image to the control. You can either provide a filename (or internal icon name - e.g. #about for the internal about icon), or an Image object that you obtained from the DOpus.LoadImage or Script.LoadImage methods.
label
string or
object:Image
Set or query the control's label or title. Not all controls have labels - this will have no effect on controls (like the list view) that don't.
Note that for combo box controls, this property is only valid for an editable combo - that is, one that you can type your own text into. You can use this property to set or query the current value of the editable text.
For a static control set to "image" mode, you can also provide an Image object that you obtained from the DOpus.LoadImage or Script.LoadImage methods. This is the same as using the image property.
For a tab control, you can set or query the labels of the individual tabs by specifying an index; e.g. Control.label(0) would reference the label of the first tab.
lines
int
For applicable controls (multiline edit control, details mode listview, listbox and scrollable markup text) returns the total number of lines of content contained in the control.
mode
string
For a list view control, lets you change or query the current view mode. Valid values are icon, details, smallicon, list. For a list edit control, lets you change or query the "edit as text" setting. Valid values are text and buttons.
readonly
bool
Set or query the read only state of an edit control.
redraw
bool
Set or query the redraw state of the control. Some controls let you turn off redrawing in order to make multiple changes without visible flicker (for example, adding a large number of items to a list view). Set to False to turn off redraw, or True to turn redraw back on after changing the control.
rotate
int
For a static text control set to "image" mode, you can set this property to rotate the displayed image. The value provided is the number of degrees from the image's initial orientation.
style
string
For a static text control, this property is used to set or query the font styles used to display this control's label. The string consists of zero or more characters; valid characters are b for bold and i for italics.
For a palette control, this property lets you set or query the control's options using various style flags. Valid flags are:
aPalette type: alpha
tPalette type: transparent
dPalette type: default
nNo arrow
cCan disable
mDecimal
textbg
string
Set or query the color used for the text background (fill) of this control. This is in the format #RRGGBB (hexadecimal) or RRR,GGG,BBB (decimal).
Currently only list view controls are supported for this property.
title
string or
object:Image
Alternative name for the label property. The term title is used in the dialog editor and XML resources, and can also be used here as a convenience.
topline
int
For applicable controls (multiline edit control, details mode listview, listbox and scrollable markup text) returns the index of the line currently displayed at the top of the control. You can set this value to change the scroll position in the control.
type
string
Returns a string indicating the type of the control.
userdata
anything
Lets you associate a data value with the control. Opus makes no use of this value, it's only for your own use.
value
string or
bool or
int or
DialogListItem or
Vector or
Date
Set or query the control's value. The meaning of this property depends on the type of the control:
  • Edit control: Returns or accepts a string representing the current contents of the edit control.
  • Check box: For a simple on/off check box, returns or accepts a bool - True for checked and False for unchecked. For a tri-state check box, returns or accepts an int - 0 for unchecked, 1 for checked and 2 for the indeterminate state.
  • Radio button: Returns or accepts a bool - True for checked and False for unchecked.
  • Tab: Returns or accepts an int indicating the currently selected page in the tab control.
  • List box / combo box / list view: Returns or accepts a DialogListItem representing the selected item. When setting the value it also accepts an int representing the 0-based index of the selected item.
  • Palette control: Returns the current color value. The color string is prefixed with a ! character if the palette button's checkbox is disabled. You can set the color this way as well. You can also set the value to "enable" or "disable" to change the checkbox state without affecting the color.
  • Date/Time control: Returns a Date object if a valid date or time is chosen. If the "Show None" property is enabled and the control has been turned off, returns the string "none".
Note that for a multiple-selection list box or list view, this value will return a Vector of DialogListItem objects, representing all currently selected items.
visible
bool
Set or query the visible state of the control. Returns True if the control is visible and False if it's hidden. You can set this property to hide or show the control.
visiblelines
int
For applicable controls (multiline edit control, details mode listview, listbox and scrollable markup text) returns the total number of lines of content visible at one time.
x
int
Set or query the left (x) position of the control, in pixels.
y
int
Set or query the top (y) position of the control, in pixels.
AddGroup
<string:name>
<int:id>
[<string:flags>]
int
Adds a new group to a list view control. Items you add to the list can optionally be placed in groups. Each group must have a unique ID.
The optional flags are "c" (group is collapsible) and "d" (group starts out collapsed). E.g. AddGroup("Unimportant", 100, "cd") would add a group called Unimportant that is initially collapsed.
AddItem
<string:name>
[<int:value>]
[<int:groupid>]
or
<object:item>
[<int:groupid>]
or
<Vector>
[<int:value>]
[<int:groupid>]
int
Adds a new item to the control (list box, combo box or list view). The first parameter is the item's name, and the optional second parameter is a data value to associate with the item.
When adding to a grouped list view, the optional third parameter provides the ID of the group you want to add the item to (the second parameter must be provided in this case, and can be set to 0 if no value is required).
The item is added to the end of the list.
Instead of the name and value you can also pass a DialogListItem object obtained from another control. This will copy the name and value from the existing item, but won't copy its group (since the new list may have different groups). You can assign the new item to a group with the optional second parameter.
For a list view control, you can also pass:
  • A Vector (or JScript array) of strings to add an item and its subitems all at once.
  • A two-dimensional array to add multiple items, each with their own sub-items.
  • A Vector of Map items to add multiple items and subitems, specifying the column names directly. Each Map should contain key/value pairs for the column data to insert. By default the column titles are used as the keys but you can specify different (language-neutral, for example) keys with the SetColumnPropertyNames method.
The return value indicates the position in the list of the new item.
If you are adding to a listview control and need to add an item with multiple columns, you can do it like this (JScript):
var i = listview.AddItem("This is col 1");
listview.GetItemAt(i).subitems(0) = "This is col 2";
listview.GetItemAt(i).subitems(1) = "This is col 3";
For a tab control, this lets you add back a tab that you've previously removed via the RemoveItem method. Only the name argument is used, which indicates the name of the child dialog to add back to the control.
AddText
<Map:text>
int
Adds a text string as an overlay on a static control in image mode (i.e. lets you overlay text on images).
The text parameter must be a Map object (created via the DOpusFactory.Map method, with the following member values to define the text. All values are optional.
textThe text to display
colorRGB string that specifies the text color
backRGB string that specifies the background color, or "none" for transparent
shadowRGB string that specifies the shadow color
alphaAlpha level from 1-255
xx coordinate offset (relative to the anchor)
yy coordinate offset (relative to the anchor)
wabsolute width (positive value) or extra padding (negative value)
habsolute height (positive value) or extra padding (negative value)
anchoranchor position; one of tl (top-left), tm (top-middle), tr (top-right), ml (middle-left), m (middle), mr (middle-right), bl (bottom-left), bm (bottom-middle), br (bottom-right)
fontfont ID to specify the font to use; must have been previously added via Dialog.CreateFont
multilineset to True to enable multiline text (line-break is a cr/lf character pair)
htmlset to True to enable simple HTML markup
justifyspecify text justification for multiline (not supported by html). One of l (left), r (right), m (middle).
Text will be auto-sized unless a width and/or height are given using the w and h values. Setting the size causes the entire rectangle to be filled (otherwise only the area behind the text is filled).
  • Specify a positive value to set the width or height explicitly.
  • Specify -1 to still use automatic sizing, but fill the entire rectangle.
  • Set to a number less than -1 to add padding to the automatic size. For example, -5 would add 4 pixels of padding.
This method returns a numeric ID for the text which lets you modify and remove it.
AutoSize
[<bool:height>]
bool
Autosizes the control, if the control type supports autosize. Returns True if the control was autosized.
If the optional height parameter is set to true, the control will be autosized vertically as well as horizontally.
ClientToScreen
<int:X>
<int:Y>
Rect
Takes an x,y pixel position relative to the control's client area and returns the same coordinates relative to the whole screen.
The client area is the area inside the control, usually excluding the control's frame if it has one. The screen coordinates are relative to the top-left corner of the primary monitor. Coordinates can be negative if the mouse is to the left or top of the respective areas.
While a rectangle is returned, only the left and top coordinates are meaningful. The width and height will always be zero.
DeselectItem
<int:position>
or
<object:item>
int
This method is mainly for use with multiple-selection list box and list view controls. It lets you deselect individual items in the control while leaving other items selected (or unaffected).
You can specify either the index of the item to select (0 means the first item, 1 means the second and so on) or a DialogListItem object obtained from the GetItemAt or GetItemByName methods.
You can also specify -1 to deselect all items in the list box.
DeselectItemByData
<int:data>
int
Searches the control for an item with its data property set to the specified value, and deselects it. Returns the item's index (or -1 if not found).
EnableGroupView
<bool:enable>
none
Only applies to list view controls. By default group view is off; after adding groups with the AddGroup method, use EnableGroupView to turn group view on.
ExpandGroupByName
<str:name>
<bool:expand>
none
For grouped list view controls, lets you expand/collapse one or more groups by name rather than having to do it one at a time via GetGroupById. The name argument can specify a wildcard to match more than one group at once (e.g. ExpandGroupByName("*", false); will collapse all groups).
GetItemRect
<int:item>
[<int:subitem>]
Rect
Returns a Rect object containing the position of the specified item or subitem. Works with listview, listbox and tab controls. The first argument is the item's index; for listviews in details mode, a second argument providing the subitem's index can optionally be provided. The rectangle is returned in client coordinates relative to the control; you can use the ClientToScreen method to convert to screen coordinates if needed.
GetGroupById
<int:id>
DialogListGroup
Returns a DialogListGroup object representing the group with the specified ID that you've previous added to a list view control using the AddGroup method.
GetItemAt
<int:position>
DialogListItem
or <string>
Returns a DialogListItem object representing the item contained in the control at the specified index (list box, combo box or list view). Item 0 represents the first item in the list, item 1 the second, and so on. For a tab control, this returns the name of the dialog whose tab is at the specified index.
GetItemByData
<int:data>
DialogListItem
Searches the control for an item with its data property set to the specified value.
GetItemByLabel
GetItemByName
<string:name>
DialogListItem
or <int>
Returns a DialogListItem object representing the item contained in the control with the specified name (list box, combo box or list view). This method has two names (…Label and …Name) for historical reasons, you can use either method name interchangeably). For a tab control, this returns the index of the dialog within the tab.
InsertItemAt
<int:position>
<string:name>
[<int:value>]
[<int:groupid>]
or
<int:position>
<object:item>
[<int:groupid>]
or
<int:position>
<Vector>
[<int:value>]
[<int:groupid>]
int
Inserts a new item in the control (list box, combo box or list view). The first parameter is the position to insert the item at (0 means the beginning of the list, 1 means the second position and so on). The second parameter is the item's name, and the optional third parameter is a data value to associate with the item.
When adding to a grouped list view, the optional fourth parameter provides the ID of the group you want to add the item to (the third parameter must be provided in this case, and can be set to 0 if no value is required).
Instead of the name and value you can also pass a DialogListItem object obtained from another control. This will copy the name and value from the existing item, but won't copy its group (since the new list may have different groups). You can assign the new item to a group with the optional third parameter.
For a list view control, you can also pass a Vector (or JScript array) of strings to add an item and its subitems all at once. You can also pass a two-dimensional array to add multiple items, each with their own sub-items.
For a tab control, this lets you add back a tab that you've previously removed via the RemoveItem method. Only the position and name arguments are used. The name argument indicates the name of the child dialog to add back to the control.
InvertSelection
none
none
Inverts the selection status of all items in the control.
ModifyText
<Map:text>
<int:id>
none
Modifies an existing text element in a static control. The id argument indicates the text element to modify, this is returned by the AddText method. See the AddText method for a description of the text argument.
MoveItem
<int:position>
or
<object:item>
<int:newposition>
int
Moves an existing item to a new location (list box, combo box, list view or tab). The first parameter is the item to move (you can pass either its index or a DialogListItem object), and the second parameter is the new position the item should be moved to.
The return value indicates the position in the list of the moved item.
RemoveGroup
<int:id>
none
Removes the specified group from a list view control.
RemoveItem
<int:position>
or
<object:item>
none
Removes an item from the control (list box, combo box, list view or tab). You can provide either the index of the item to remove (0 means the first item, 1 means the second and so on) or a DialogListItem object obtained from the GetItemAt or GetItemByName methods.
You can also specify -1 to completely clear the contents of the control, removing all items at once.
RemoveItemByData
<int:data>
int
Searches the control for an item with its data property set to the specified value, and removes it. Returns the item's index (or -1 if not found).
RemoveText
<int:id>
none
Removes a text element from a static control. The id argument indicates the text element to remove, this is returned by the AddText method.
ScreenToClient
<int:X>
<int:Y>
Rect
Takes an x,y pixel position relative to the whole screen and returns the same coordinates relative to the control's client area.
SelectItem
<int:position>
or
<object:item>
or
<string:tab>
int
Selects an item in the control. For a list box, combo box or list view, you can specify either the index of the item to select (0 means the first item, 1 means the second and so on) or a DialogListItem object obtained from the GetItemAt or GetItemByName methods.
For a multiple-selection list box or list view you can also specify -1 to select all items in the control.
For a tab control, you can change which page is visible by specifying the name of the page (i.e. the name of the child dialog) to show.
The return value indicates the new selected index.
SelectItemByData
<int:data>
int
Searches the control for an item with its data property set to the specified value, and selects it. Returns the item's index (or -1 if not found).
SelectRange
<int:start>
<int:end>
or
<object:item1>
<object:item2>
object:Vector
Selects text within an edit control (or the edit field in a combo box control). The two parameters represent the start and end position of the desired selection. To select the entire contents, use 0 for the start and -1 for the end.
The return value is a Vector with two members that provide the current start and end of the selection. To query the range without changing it, simply call the SelectRange method with no arguments.
In a list box or list view control, this method selects a range of items.
object:Vector
none
Lets you specify language-neutral column names for a listview control. You can them add items and subitems using name/value pairs with the AddItem and InsertItemAt methods.
This method takes a Vector of strings; each string corresponds to a column in the listview.
SetFont
<int:id>
none
Sets the font used by the control to the specified font. The id parameter must have come from a previous call to Dialog.CreateFont. You can use 0 to reset the font to its default.
SetItemWidth
<int:width>
none
Sets the width in pixels of items in a list view control that's set to list or smallicon mode. Specify -1 to automatically size the items.
SetPos
<int:x>
<int:y>
none
Sets the position of this control. The x and y coordinates are specified in pixels.
SetPosAndSize
<int:x>
<int:y>
<int:cx>
<int:cy>
none
Sets the position and size of the control, in a single operation. All coordinates are specified in pixels.
SetSize
<int:cx>
<int:cy>
none
Sets the size of this control. The cx (width) and cy (height) values are specified in pixels.
SetSyntax
<str:type>
none
For edit controls set to use the code editor, this allows you to enable syntax highlighting. The type string can be "jscript", "vbscript" or "eval" to use one of the standard syntaxes. You can also specify your own custom syntax details.
SetTooltip
<string:tip>
none
Assigns a tooltip to this control, which will be shown when the mouse hovers over it. Pass an empty string to remove an existing tooltip.
SortGroups
<int:dir>
or
<callback>
none
Sorts the groups in a listview control. You can use this in two ways:
  • Call with a 1 or -1 to sort groups alphabetically (1 = forward, -1 = reverse).
  • Call with a callback function to implement custom sort order. Your callback will be called with two DialogListGroup objects, and should return the result of the comparison between the two (<0 if group1 < group2, 0 if group1 == group2, >0 if group1 > group2)
SortItems
<int:index>
[<str:flags>]
or
<callback>
[<int:column>]
none
Sorts the items in a listview control. You can use this in two ways:
  • Call with a 1-based column index to sort by that column. Use a negative number for a reverse sort.
  • Call with a callback function to implement custom sort order. Your callback will be called with two DialogListItem objects, and should return the result of the comparison between the two (<0 if item1 < item2, 0 if item1 == item2, >0 if item1 > item2)
When used with a custom sort callback, the second argument lets you specify the current sort column. The arrow indicator in the sort header will be updated to reflect the new column.
When given a column to sort by, the second argument is a flags value. Currently the only flag defined is "n", which performs a numeric string sort rather than a standard lexicographical sort.
