Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:configurescriptdata
If a script add-in provides an OnConfigureScript method, it is passed a ConfigureScriptData object when invoked via the user clicking the Configure button in the Script Management dialog.
window
int
This is a handle to the parent window that the script should use if displaying a dialog via the Dialog object. Even though this is not a Lister or Tab, it can still be assigned to the Dialog.window property to set the parent window of the dialog.
