Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:column
The Column object represents an information column displayed in a tab (e.g. name, size, attributes, etc). A collection of Column objects can be retrieved from the Format.columns property.
<default value>
string
Returns the name of the column.
autosize
bool
Returns True if the column width is set to auto.
collapse
bool
Returns True if the column width is set to collapse.
expand
bool
Returns True if the column width is set to expand.
fill
bool
Returns True if the column width is set to fill.
header
string
Returns the name of the column as displayed in the Lister column header.
label
string
Returns the name of the column as displayed in the Columns tab in the Folder Options dialog.
max
int or string
Returns the maximum width of the column in pixels, or the string "fill" if the maximum is set to fill.
min
int
Returns the minimum width of the column in pixels.
name
string
reverse
bool
Returns True if the sort direction of the column is reversed.
sort
int
Returns the sort order of the column (e.g. 1 for the primary sort field, 2 for the secondary sort field, etc). Returns 0 if the display is not sorted by this column.
width
int
Returns the current display width of the column in pixels.
