Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:closelisterdata
If a script add-in implements the OnCloseLister event, the method receives a CloseListerData object before a Lister is closed.
lister
object:Lister
Returns a Lister object representing the Lister that is closing.
prevent_save
bool
Set this to True to prevent the closing Lister from being saved as the new default Lister.
qualifiers
string
Returns a string indicating any qualifier keys that were held down by the user when the event was triggered.
The string can contain any or all of the following: shift ctrl, alt, lwin, rwin
If no qualifiers were down, the string will be: none
shutdown
bool
Returns True if the Lister is closing because Opus is shutting down.
