Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:clipboardchangedata
If a script add-in implements the OnClipboardChange event, the method receives a ClipboardChangeData object whenever the system clipboard contents change.
count
int
Returns a count which increments each time the clipboard contents change (when Opus is running).
has_files
bool
Returns True if the clipboard now contains files.
