Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:audiocoverart
The AudioCoverArt object provides access to an audio file's embedded cover art. It is obtained through the AudioMeta.coverart property.
<default value>
string
Returns a string indicating the intended use for this cover art. Possible values are artist, back, band, bandlogo, colorfulfish (this is unfortunately part of the ID3 specification), composer, conductor, front, icon, illustration, leadartist, leaflet, location, lyricist, media, other, otherfileicon, performance, publisherlogo, recording, vidcap.
data
object:Blob
Returns a Blob object representing the actual image data.
depth
int
Returns the bit depth of this image.
desc
string
Returns the description of this image (if any).
ext
string
Returns the default file extension for this image, if it can be determined.
height
int
Returns the height of this image, in pixels.
mime
string
Returns the image's MIME type, if specified in the file.
size
object:FileSize
Returns a FileSize object representing the size of the image data.
type
string
Returns a "pretty" form of the intended use string (i.e. the default value), translated to the current Opus user interface language.
width
int
Returns the width of this image, in pixels.
