Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:aliases
The Aliases object holds a collection of all the defined folder aliases. It is retrieved from the DOpus.aliases method.
<default value>
collection:Alias
You can enumerate the Aliases object, or query the value of an individual alias by name (e.g. DOpus.Output(DOpus.aliases("desktop").path);)
Add
<string:name>
<string:path>
none
Adds a new alias to the system with the specified name and path. Note that you should not provide the leading forward-slash (/) in the alias name.
Delete
<string:name>
none
Deletes the specified alias.
Update
none
none
Updates the state of this object. When the Aliases object is first retrieved via DOpus.aliases, a snapshot is taken of the aliases at that time. If you make changes via the object it will reflect them but any changes made outside the script (e.g. via the Favorites ADD=alias command) will not be detected unless you call the Update method.
