Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:alias
An Alias object represents a defined folder alias. It is retrieved by enumerating or indexing the Aliases object.
<default value>
string
Returns the name of the alias.
path
object:Path
Returns the target of the alias as a Path object.
system
bool
True if the object is a system-defined alias, False if it is user defined.
