Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:activatetabdata
If a script add-in implements the OnActivateTab event, the method receives an ActivateTabData object whenever the activation state of a tab changes.
closing
bool
Returns True if the activation change is due to the old tab being closed.
newtab
object:Tab
Returns a Tab object representing the tab that has become active.
oldtab
object:Tab
Returns a Tab object representing the tab that has gone inactive.
qualifiers
string
Returns a string indicating any qualifier keys that were held down by the user when the event was triggered.
The string can contain any or all of the following: shift ctrl, alt, lwin, rwin
If no qualifiers were down, the string will be: none
