Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:toolbars
The Toolbars object lets you enumerate all the defined toolbars in your Directory Opus configuration (whether currently turned on or not). It's retrieved using the DOpus.Toolbars method.
<default value>
collection:Toolbar
Returns a collection of Toolbar objects that you can enumerate.
fdb
string
or
Vector:string
Returns the name(s) of the currently selected File Display Toolbar(s).
If the FDB toolbar is disabled, returns the string !static to indicate a static header.
If there is only one FDB toolbar configured (the usual case), it is returned as a simple string.
If more than one FDB toolbar is configured, a Vector of strings is returned.
You can use DOpus.toolbars.fdb(0) in both JScript and VBScript if you just want the name of the first toolbar without worrying about whether the number of other toolbars (if any). Otherwise, use TypeName(…) in VBScript and typeof in JScript to determine the return type.
viewer
string
Returns the name of the currently selected Viewer Toolbar.
