Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:toolbar
The Toolbar object represents a toolbar. Toolbar objects can represent a specific instance of a toolbar (open in a specific Lister), and can also represent the toolbar itself, on disk, that doesn't have to currently be open at all.
  • When retrieved from the Toolbars object (which in turn comes from the DOpus.Toolbars method), the object represents a toolbar on disk. You can find out where it is currently in use from its properties.
  • When retrieved from the Lister.toolbars property, it represents an instance of a toolbar in that particular Lister.
<default value>
string
Returns the name of the toolbar.
deftoolbar
bool
Returns True if this is a default (factory-provided) toolbar, or False if it was user-created.
(Old scripts may use "default" instead of "deftoolbar"; this is deprecated because it does not work in JScript where "default" is a reserved keyword.)
listers
collection:Lister
Returns a collection of Lister objects representing any and all Listers this toolbar is currently open in.
docks
collection:Dock
Returns a collection of Dock objects representing any currently floating instances of this toolbar.
group
string
Returns a string indicating the group (position) of a particular instance of this toolbar. The returned string will be one of top, bottom, left, right, center, fdright, fdbottom, tree.
line
int
Returns the line number within the toolbar's group that it resides on. For example, the first toolbar at the top of the Lister would have a line of 0.
pos
int
Returns the pixel position from the left/top of the toolbar's line. If there are two or more toolbars with the same line number, the pos value determines the order they appear in.
