The TabGroups object lets your script query and modify the configured Folder Tab Groups. You can obtain a TabGroups object from the DOpus.TabGroups property.
The TabGroups object is a collection of TabGroup objects; you can enumerate it to discover the top-level tab groups and folders. Folders can also be enumerated to discover the tab groups and folders they contain, and so on.
Method Name | Arguments | Return Type | Description |
AddChildFolder |
<object:TabGroup> or <string:name> |
object:TabGroup |
Adds a new folder to the list of tab groups. You can either provide a TabGroup object (which has the folder property set to True) or the name for the new folder. If the operation succeeds a TabGroup object is returned which represents the new folder. If the operation fails False is returned. |
AddChildGroup |
object:TabGroup |
Adds a new tab group to the list of tab groups. You can either provide a TabGroup object or the name for the new group. If the operation succeeds a TabGroup object is returned which represents the new tab group. If the operation fails False is returned. |
DeleteChild |
<object:TabGroup> |
none |
Deletes the child item (folder or tab group). |
Save |
none |
none |
Saves the tab group list and any changes you have made. var tabGroups = DOpus.TabGroups;
var group = tabGroups.AddChildGroup("New Tab Group");
if (!group)
DOpus.Output("Group already exists");
else {
group.desc = "Example description";
var tabs = group.tabs;
tabs.AddTab("C:\\");
tabGroups.Save();
// This will not work correctly.
var group = DOpus.TabGroups.AddChildGroup("New Tab Group");
if (!group)
else {
group.tabs.AddTab("C:\\");
DOpus.TabGroups.Save(); // <-- Incorrect
Update |
none |
none |
Updates the TabGroups object to reflect any changes made through the Preferences user interface. |
