Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:sourcedestdata
If a script add-in implements the OnSourceDestChange event, the method receives a SourceDestData object to indicate which tab's state changed.
dest
bool
Returns True if the tab is now the destination.
source
bool
Returns True if the tab is now the source. If both source and dest return False it indicates that the tab is now "off".
qualifiers
string
Returns a string indicating any qualifier keys that were held down by the user when the event was triggered.
The string can contain any or all of the following: shift ctrl, alt, lwin, rwin
If no qualifiers were down, the string will be: none
tab
object:Tab
Returns a Tab object representing the tab.
