Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:shellproperty
The ShellProperty object represents a shell property - an item of metadata for a file or folder that comes from Windows or third-party extensions (as opposed to metadata from Opus's native metadata system).
The FSUtil.GetShellPropertyList method lets you retrieve a list of available shell properties. You can then use FSUtil.GetShellProperty or Item.ShellProp to retrieve the value of a property for a particular file.
defwidth
int
The default width in pixels a column displaying this property should use.
display_name
string
The display name of this property (the name that should be shown to users).
isviewable
bool
The property is intended to be viewed by the user (e.g. in a column).
justify
string
The default column justification for this property (left, right, center).
pkey
string
The PKEY (property key) for this property. This is a property's unique ID and the canonical way to refer to a property. You can use the raw_name and display_name values to access properties as well, but they are potentially inaccurate (since it's possible to have two properties with the same name) and also slower as the property has to be looked up by name each time.
raw_name
string
An internal name used by the property provider.
type
string
The type of data this property returns; string, number, datetime are the only supported types currently.
