Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:scriptstrings
The ScriptStrings object is returned by the DOpus.strings property. It lets you access any strings defined via string resources.
langs
object:Vector
Returns a Vector of strings representing the languages that strings have been defined for.
Get
<string:name>
<string:language>
string
Returns the text of a string specified by name. The name must match the name used in the string resources.
Optionally you can provide a language name as the second parameter, to retrieve a string from a particular language. Otherwise, the string is returned in the current language.
GetEscaped
<string:name>
<string:language>
string
Returns the text of a string specified by name. This works the same as the Get method but interprets Javascript-style embedded escape characters in the string. E.g. \n in the string is converted to a new line.
HasLanguage
<string:language>
bool
Returns True if strings in the specified language are defined in the resources.
