Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:scheduledtimerdata
A script add-in can use the DOpus.SetScheduledTimer method to create timers, which will call your OnScheduledTimer method when the desired date/time is reached.
id
string
Returns the ID of the timer that your method is being called for.
