Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:quickfilterchangedata
If a script add-in implements the OnQuickFilterChange event, the method receives a QuickFilterChangeData object when the quick filter is changed in a tab.
tab
object:Tab
Returns a Tab object representing the tab the quick filter changed in.
