Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:periodictimerdata
A script add-in can use the DOpus.SetTimer method to create timers, which will call your OnPeriodicTimer method at the rate you specify.
id
string
Returns the ID of the timer that your method is being called for.
