Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:pairedfolder
The PairedFolder object is returned by the FSUtil.GetFolderPair method when you query for a folder's pair.
Make sure you check the valid property before querying any others - if valid is False it means the folder had no pair, so none of the other properties will exist.
dual
bool
Returns True if the Default dual display folder option is on for the pair.
dualnavlock
bool
Returns True if the Default Navigation Lock target option is on for the pair.
ifnonexistent
string
Returns a string indicating the setting of the If non-existent option. Valid values are gotoparent, ignorepair and useanyway.
navlock
bool
Returns True if the Turn on Navigation Lock automatically option is on for the pair.
parent_level
int
If the initial paired folder didn't exist and so the returned path is a parent folder (as a result of the If non-existent option), this property tells you how many levels above the initial pair the returned folder is.
path
object:Path
Returns a Path object which provides the paired folder.
primaryonleft
bool
Returns True if the Always display primary folder at the left/top option is turned on.
sync
bool
Returns True if Default Synchronize target is turned on for the pair.
subfolders
bool
Returns True if the Apply Settings to all sub-folders option is on.
valid
bool
Returns True if the paired folder is valid.
