Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:orderedmap
The OrderedMap object is an associative container and is identical to the Map object except for the ordering of items within the map.
Whereas the regular Map object sorts items alphabetically by key, the OrderedMap preserves the order that items are added.
You can create a new OrderedMap using the DOpusFactory.OrderedMap method. All Opus script methods documented as accepting a Map object can also accept an OrderedMap.
See the documentation of the Map object for more information.
