Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:msg
The Msg object represents a script dialog input event message. It’s returned by the Dialog.GetMsg method which you call when running the message loop for a detached dialog.
<default value>
bool
Returns True if the message is valid, or False if the dialog has been closed (which means you should exit your message loop).
buttons
string
Returns a string indicating which mouse button was pressed when the message was generated. Possible values are left, right and middle.
checked
int
If the event type is checked, this indicates the check state of the item. If checkboxes are used in automatic mode, this will be the new check state of the item. In manual mode, this will indicate the existing state and it's up to you to change the state if desired.
Check states are:
0unchecked
1checked
2indeterminate
3unchecked/disabled
4checked/disabled
5indeterminate/disabled
control
string
Returns the name of the control involved in the event. You can get a Control object representing the control by passing this string to the Dialog.Control method.
  • For a timer event this returns the name of the timer that was triggered.
  • For a hotkey event this returns the name of the hotkey.
  • For a drop event this returns the name of the control that the files were dropped on.
  • For a tab event this tells you which monitored tab the event occurred in (either the ID you assigned in the Dialog.WatchTab method, or the numeric handle of the tab if you didn't assign an ID).
  • For a dirchange event this tells you which watcher detected a file or folder change (the ID you assigned via the Dialog.WatchDir method).
  • If you have added an icon to the taskbar via the Dialog.NotifyIcon method, notifyicon indicates an event associated with that icon.
  • For a http event this tells you the ID of the HTTPRequest object.
  • For a custom message, this provides the name of the message.
cx
int
For move and resize events, this property returns the new width of the dialog.
The dialog must have want_move or want_resize set to receive these events.
cy
int
For move and resize events, this property returns the new height of the dialog.
data
int or// bool//
If the event type is focus, indicates the new focus state of the control - True if the control has gained the focus, or False if it's lost it.
For a combo box or list box control: If the event type is selchange or dblclk, returns the data value associated with the selected item.
For a two-state check box control or radio button: If the event type is click, returns a bool indicating the current check state.
For a three-state check box: If the event type is click, returns an int representing the current state.
For a date/time picker control, this value will be true if a valid date is selected, or false if the date is turned off (only applies if the "Show None" property is enabled).
If the event type is timer, this value indicates the number of milliseconds that have elapsed since the last time this timer was triggered.
If the event type is tab, and the value property is set to filechange, this indicates which file change events occurred in the monitored tab. 1 = add, 2 = delete, 4 = change. The values will be added together (so e.g. 6 indicates at least one item was changed and at least one was deleted).
For a http event, this value contains the event status code. The value property provides the same information as a keyword.
For a color event from a palette control, this will be 0 for an intermediate color change (e.g. the user has the palette open and is clicking around within it) and 1 for final changes (when the palette window closes).
For a custom message sent from another script, this may be the optional numeric parameter that can be sent with the message. Scripts can also send a container object like a Map and this will be found in the object property instead.
For a hash message, this provides the request ID returned by the FSUtil.Hash method.
For a key message, this provides the virtual key code of the pressed key. Virtual key codes are listed here.
For a run message, this provides the ID of the launched program that completed.
dialog
string
Returns the name of the parent dialog.
event
string
Returns a string indicating the event that occurred. Currently defined events are:
checkedFor a listview control with the Checkboxes property enabled, indicates that the checkbox of a list item has been clicked.
clickThe control was clicked (e.g. a button, check box, radio button, markup text or static control with Notify Clicks property enabled). For a list edit control, the data value will be 1 for the reset button and 2 for the options button.
clipboardSent whenever the system clipboard contents change, once monitoring has been enabled with the Dialog.WatchClipboard method.
closeThe user clicked the dialog's close button. Only generated if the Dialog.want_close property has been set to True. You'll need to close the dialog manually using the Dialog.EndDlg method.
colorA new color has been chosen in a palette control.
customA custom message sent from another script. The message name can be found in the name property.
datetimeThe date has changed in a date/time picker control.
dblclkAn item in the list was double-clicked (list box, combo box or list view) or the control was double-clicked (static control with Notify Clicks property enabled).
deleteThe delete button has been clicked on an item in a list edit control.
dirchangeA file or folder that you established monitoring of via the Dialog.WatchChanges method has changed. The control property tells you which watcher was triggered.
dragThe user has initiated a drag and drop from a static or list view control. You can respond by calling the Dialog.Drag method. The Drag Source property must be enabled on the control for this event to be generated.
dropFiles were dropped onto your dialog. The dialog template must have its Accept Drops property set to True to enable drag & drop support.
editchangeThe contents of an edit field were modified. For a list view this event indicates that the label of a list item was edited.
enterThe Enter key was pushed in an edit control with the Enter property enabled).
focusThe control gained or lost focus.
hashAn asynchronous hash calculation requested via FSUtil.Hash has returned.
hotkeyA key combination added as a hotkey with the Dialog.AddHotkey method has been pressed.
httpAn event associated with a HTTPRequest has occurred.
invalidThe dialog has been closed
keyA key was pressed in a control. Currently only supported by list view controls.
modeThe mode has changed in a list edit control (the "edit as text" option has been changed).
moveThe dialog was moved. Only generated if the Dialog.want_move property has been set to True. Related to resize event below.
rclickAn item in the list was right-clicked (list box, list view) or the control was right-clicked (static control with Notify Clicks property enabled, or button control with the Right Button property enabled).
runA program launched asynchronously via the FSUtil.Run() method has completed. The data property identifies the task, and the state and object properties provide information from the program.
pushA button with the Arrow and Split properties both set to true will generate this message when the arrow part of the button is clicked.
resizeThe dialog was resized. Only generated if the Dialog.want_resize property has been set to True. Don't mix manual and automatic resizing with the same control: If you move or resize a control in response to this event, the control should not have any of the resize flags set in the dialog editor.
selchangeThe selection was changed (list box, combo box, list view or tab).
sortA listview's column sort header has been clicked. The 1-based column index is provided in the index property.
tabAn event has occurred in a tab monitored using the Dialog.WatchTab method.
timerA periodic timer created with the Dialog.SetTimer method has elapsed.
focus
bool
Returns True if the control had focus when the message was generated.
index
int
Returns the current selection index for a combo box, list box or tab control. Returns the column index for a list view "sort" event.
mousex
int
Returns the horizontal position of the mouse cursor when the message was generated.
mousey
int
Returns the vertical position of the mouse cursor when the message was generated.
name
string
An alias for the control property.
object
variant
For a drop event, this property returns a Vector of Item objects, representing the files that were dropped onto your dialog.
For a custom message sent from another script, this may be the optional container object (e.g. a Map) that can be sent with the message. Scripts can also send a numeric parameter and this will be found in the data property instead.
For a date/time picker control, this property returns a Date object when a new valid date is chosen.
For a hash message this returns the calculated hash value; it will either be a string, or a Vector of strings, depending on how many hash methods were requested in the call to FSUtil.Hash.
For a run message this returns the RunResults object from the completed program.
qualifiers
string
Returns a string indicating the qualifier keys (if any) that were held down when the message was generated.
The string can contain any or all of the following: shift, ctrl, alt, lwin, rwin
If no qualifiers were down, the string will be: none
result
bool
Returns True if the message is valid, or False if the dialog has been closed.
state
bool
For a run message this indicates whether the program was launched successfully or not.
subitem
int
Returns the subitem (column) number for listview controls with rclick and dblclk events.
tab
string
For a dialog tab control, returns the name of the parent tab (if the control is on a dialog that's inside a tab control).
If the event type is tab, this returns a Tab object representing the monitored tab that the event occurred in. Calling this repeatedly may be inefficient.
value
string
For the dblclk, editchange and selchange events, returns the current contents of the edit field (or selected item label).
For the tab event, indicates which event occurred in the monitored tab. Possible values are select, navigate, filechange, activate, srcdst, view, flat, and close (sent if the tab is closed while you are monitoring it).
For the drag event, this indicates which button is being used to drag (left or right).
For a click event from a markup text control, this indicates the ID of the clicked link.
For a http event, this indicates the current http status code.
For a color event from a palette control, this will be the selected color as either a hex or decimal string (depending on the control property). If the palette button's checkbox is disabled, this will be prefixed by a ! character.
For a date/time picker control, this returns the textual value of the selected date or time. The object property returns a Date object, which may be more useful.
For a key message this provides the pressed key in text form (e.g. "space").
x
int
For move and resize events, this property returns the new x position of the dialog. May be negative on multi-monitor systems.
y
int
For move resize events, this property returns the new y position of the dialog. May be negative on multi-monitor systems.
