Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:filechange
The FileChange object provides information about a file changed by a command. If you set the Command.logchanges property to true, a collection of any file changes can be obtained from the Command.results property once the command is complete.
action
string
Returns a string indicating the type of file change:
createA file was created.
createunknownA file or directory was created.
changeA file was modified.
changewriteA file was written to.
delfileA file was deleted.
deldirA directory was deleted.
delunknownA file or directory was deleted.
makedirA directory was created.
renameA file or folder was renamed.
file
string
The name of the file or folder that changed.
file2
string
The secondary name, if any.
path
Path
The path the change occurred in.
path2
Path
The secondary path, if any.
