Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:everythingresult
Represents a single item returned in the result set from an Everything query. A Vector of these objects is returned by a call to the EverythingInterface.Query method.
When you send a query to everything you can tell it what information to return. Only information you request will appear in the result items, so e.g. if you want the file size, you must request it when you send the query.
access
access_utc
date
Returns the last access date (in local and UTC time) of the result item. The last access date must have been requested in the query.
create
create_utc
date
Returns the creation date (in local and UTC time) of the result item. The creation date must have been requested in the query.
daterecentlychanged
daterecentlychanged_utc
date
Returns the recently changed date (in local and UTC time) of the result item. The value must have been requested in the query.
daterun
daterun_utc
date
Returns the last run date (in local and UTC time) of the result item. The value must have been requested in the query.
filelist_filename
string
Returns the file list filename of the result item. The value must have been requested in the query.
fullpath
object:Path
Returns the full path and name of the result item. The full path and name (or the path and name separately) must have been requested in the query.
highlighted_fullpath
string
Returns the highlighted full path and name of the result item, if the value was requested in the query.
highlighted_name
string
Returns the highlighted name of the result item, if the value was requested in the query.
highlighted_path
string
Returns the highlighted path of the result item, if the value was requested in the query.
name
string
Returns the name of the result item. The name (or full path and name) must have been requested in the query.
path
object:Path
Returns the path of the result item. The path (or full path and name) must have been requested in the query.
runcount
int
Returns the item's run count, if it was requested in the query.
size
object:FileSize
Returns the size of the result item, if it was requested in the query.
GetItem
none
object:Item
Constructs an Opus Item object representing this result. The full path and filename must have been returned in the result set for this function to work.
