Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:drive
The Drive object provides information about a drive (hard drive, CD ROM, etc) on your system. You can obtain a Vector of Drive objects, one for each drive on your system, from the FSUtil.Drives method. You can also get a Drive object from the Path.GetDrive method.
default value
string
Returns the root of the drive (e.g. C:\).
avail
object:FileSize
Returns a FileSize object indicating the available free space on the drive.
bpc
int
Returns the bytes-per-cluster value for the drive.
filesys
string
Returns a string representing the filesystem type.
flags
int
Returns a value representing filesystem flags for the drive.
free
object:FileSize
Returns a FileSize object indicating the total free space on the drive.
label
string
Returns the drive's label.
ssd
bool
Returns true if the drive can be identified as solid state.
total
object:FileSize
Returns a FileSize object indicating the total size of the drive.
type
string
Returns a string indicating the drive type (removable, fixed, remote, cdrom, ramdisk).
