Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:configrestoredata
If a script add-in implements the OnConfigRestore event, the method receives a ConfigRestoreData object when the configuration is restored from a backup.
This method will be called twice; once before the restore begins, and once after Opus has restarted with the new configuration. The step property tells you which invocation this is.
location
object:Path
Returns the path of the staging area that backed up Opus configuration has been extracted to. Any changes your script makes to files in the staging folder will be imported into the Opus configuration. Note that this property is only provided if step equals "before".
step
string
Returns either "before" or "after", to indicate which invocation of the event this is.
