Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:buttondata
The ButtonData object is used to initialise a dynamic toolbar button. It's obtained from the various methods of the AddButtonHelper object. The properties of this object are used to configure the button.
Common to all types
backcol
string
Sets the background color of the button, in the format #RRGGBB (hexadecimal) or RRR,GGG,BBB (decimal).
desc
string
The button's description (tooltip).
string
The main icon for the button; you can specify either an internal icon name (e.g. #copy) or the full path of an external image file or icon. You can extract icons from DLLs etc by appending a comma and the icon index to the file name. You can also provide an Image object.
string
The secondary icon for the button.
label
string
The button's label.
The usual button label rules apply, where a & character can be placed before a character to make it an accelerator key, and && should be used for a literal &. In JScript, for example, you would normally run something like str.replace(/&/g,"&&") on strings that may contain literal & characters.
If notablabel (below) is False, you should also double any literal \ characters.
nohighlight
bool
Set to True if the button should not highlight when the mouse moves over it.
notablabel
bool
Set to True to disable interpreting of tabs in the button's label.
When False, \t within the label string will be turned into a tab character and \\ should be used to get a literal \ character.
separator
bool
Set to True to display a separator following this button.
showimage
bool or string
Controls the button image visibility. Valid values are True or False, "dual", "large", or "largedual".
showlabel
bool or string
Controls the button label visibility. Valid values are True or False, "left", "right", "top", "bottom".
textcol
string
Sets the text color of the button, in the format #RRGGBB (hexadecimal) or RRR,GGG,BBB (decimal).
Normal buttons
checked
bool
Set to True to have the button appear checked/highlighted.
disabled
bool
Set to True to disable the button.
func
string
The full function to run when the button is clicked. Multiple lines can be provided, with cr/lf separators. Any *@modifiers* need to go at the top of the function.
type
string
Sets the function type; valid values are "batch", "script", "wsl". Leave empty for a standard Opus function.
radio
bool
Set to True to use a radio button rather than a checkmark.
arrow
bool or string
Display a dropdown arrow on the menu. Valid values are True or False, "normal", or "slim".
children
AddButtonHelper
This returns another AddButtonHelper object, which lets you add child buttons to the menu.
childimages
string
Controls the visibility of images in the menu. Valid values are "off", "on", "large".
minimize
bool
Set to True to minimize the menu width.
popout
string
Control where the menu pops open. Valid values are "left", "right", "top", "bottom".
alwaysenable
bool
Set to True to always enable the dropdown even if the button itself is disabled.
checked
bool
children
AddButtonHelper
This returns another AddButtonHelper object, which lets you add child buttons to the menu component of the menu button.
childimages
string
disabled
bool
func
string
holdright
bool
Set to True to enable the "hold/right button to pop open" option.
hoverpopout
bool
Set to True to have the menu open when you hover over it with the mouse. Only applies to menu buttons inside sub-menus.
type
string
radio
bool
Three-button buttons
children
AddButtonHelper
This returns another AddButtonHelper object, which lets you add child buttons to the menu. The first button is designated left, the second is right and the third is middle.
childimages
string
Controls the visibility of images for the three-button's child buttons. Valid values are "off", "on", "large".
dynamicfromchild
bool
Enables dynamic icons/labels for the button parent based on the child buttons.
