Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:buttoncontextdata
If a script add-in adds commands that require context-sensitive state information via the the OnButtonContext event, the method receives a ButtonContextData object whenever it needs to supply state information for a button.
args
Args
Returns an Args object representing the function's parsed arguments.
cmdline
string
Provides the command line that triggered the request for context-sensitive state.
ctx
ButtonContext
Returns a ButtonContext object that is used to change the button's state.
method
string
Provides the command method name.
lister
Lister
Lister whose toolbar the button is visible on (0 if not applicable).
viewer
Viewer
Viewer whose toolbar the button is visible on (0 if not applicable).
