Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:addbuttonsdata
If a script add-in adds dynamic toolbar buttons via the the OnAddButtons event, the method receives an AddButtonsData object whenever it needs to generate or update the list of buttons.
args
Args
Returns an Args object representing the function's parsed arguments.
buttons
AddButtonHelper
Returns an AddButtonHelper object that is used to add buttons.
cmdline
string
Provides the command line being used to generate the buttons.
embedded
string
Provides the embedded function body, if supplied by the user.
lister
Lister
Lister whose toolbar the commands are being added to (0 if not applicable).
viewer
Viewer
Viewer whose toolbar the commands are being added to (0 if not applicable).
