Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_objects:addbuttonhelper
The AddButtonHelper object is used to add dynamic buttons to a toolbar. It's obtained from the buttons property of the AddButtonsData object.
AddButton
none
ButtonData
Adds a new (normal) button to the toolbar. Use the properties of the returned ButtonData object to customize the button.
AddMenu
none
ButtonData
Adds a new drop-down menu to the toolbar.
AddMenuButton
none
ButtonData
Adds a new menu button to the toolbar.
AddThreeButton
none
ButtonData
Adds a new three-button button to the toolbar.
