The OnTabClick event can be implemented by a script add-in to receive notification when a tab is clicked with a qualifier key held down. You can use this to override the default behavior (e.g. control-clicking tabs normally links them).
| Method Name: | OnTabClick |
Argument Type: |
Return Type: |
bool |
Description: |
The TabClickData.tab property identifies the tab that was clicked. You can return True from this event to prevent the default action, or False (which is the default) to allow it to proceed. |
