The OnScheduledTimer event can be implemented by a script add-in to have Opus call your script at when a specific date/time is reached. The DOpus.SetScheduledTimer method can be used to create timers, and your OnScheduledTimer method will be called at most one time for each timer you create.
Method Name: | OnScheduledTimer |
Argument Type: |
Return Type: |
none |
Description: |
The id property indicates which timer your method is being called for. |
