The OnPeriodicTimer event can be implemented by a script add-in to have Opus call your script at regular intervals. The DOpus.SetTimer method can be used to create timers, and your OnPeriodicTimer method will be called regularly for each timer you create.
| Method Name: | OnPeriodicTimer |
Argument Type: |
Return Type: |
none |
Description: |
The id property indicates which timer your method is being called for. |
